查看: 82|回复: 0
2007 335 buzzes hot
 楼主| 发表于 2019-1-28 18:06:48 来自手机 | 显示全部楼层 |阅读模式
{"text":"My driver is having a daily reoccurring problem but it happens at odd times so its hard to figure out.\n\nThis morning After driving a less than 10 miles, shut down at the dock, then returning back to the shop the high temp light/buzzer came on. Sometimes this will happen once a day, sometimes multiple times in a day.\n\nThe buzzer and light for high temp comes on. The temp gauge reads 180 but the fan has not engaged automatically yet. If he manually turns on the motor fan the buzzer goes off.\n\nDoes anyone know what temp the motor fan should kick on by its self?\nWhat temp should the high temp alarm/light come on at?\nWhere is the sensor that is setting off the buzzer?\n\nThanks, GaryG","pics":"[]","canComment":true}
GMT+8, 2026-4-16 09:14 , Processed in 0.066513 second(s), 24 queries .
