查看: 157|回复: 7
PO Only
 楼主| 发表于 2021-7-30 02:58:45 来自手机 | 显示全部楼层 |阅读模式
{"text":"As I branch off into other equipment, where do you recommend finding PO loads\n\nNegotiable rates\nConsistent hauling \n\nAnything could help, even the negative because it shows me who not to work with. ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-7-30 06:14:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"I have a load for you ","replyToPid":0}
 楼主| 发表于 2021-7-31 12:53:52 来自手机 | 显示全部楼层
1047332 发表于 2021-07-30 23:01:41 What kind of equipment exactly? 53’ ft dry van? If so, I can send you a #.
","text":"Yes van","replyToPid":438252}
发表于 2021-7-31 07:01:41 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"What kind of equipment exactly? 53’ ft dry van? If so, I can send you a #."}
发表于 2021-7-30 23:48:40 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"You name the big company they all have po loads .   Jb hunt Has a fairly good thing from time to time. "}
 楼主| 发表于 2021-7-30 11:16:06 来自手机 | 显示全部楼层
{"replyTo":"","text":"Dispatcher. My shippers I work with as a broker doesn’t have PO loads. ","replyToPid":0}
 楼主| 发表于 2021-7-30 11:17:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"Are you a broker? If so, MC?\nWhere is the load coming from?\nIs this a continuous/recurring load? \nBH available?","replyToPid":438142}
发表于 2021-7-31 23:30:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"Msg sent","replyToPid":438294}
GMT+8, 2026-2-8 15:46 , Processed in 0.071399 second(s), 24 queries .
