查看: 214|回复: 5
opinions please
 楼主| 发表于 2021-7-29 05:06:40 来自手机 | 显示全部楼层 |阅读模式
{"text":"I haven't driven from NC to AZ in a long time. I'm wanting to take the 85 to 20 to 10 instead of the 40. cheaper fuel somewhat? more flat so I'll burn less fuel? what yall think?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-7-29 16:03:07 来自手机 | 显示全部楼层
{"replyTo":"","text":"The shortest distance between two points is a ‘straight-line.’\n\nIf you want to maximize your mpg, drive at 1300-1400 rpm’s and use cruise control (but NOT when raining)\n\nMake sure tires are inflated to proper psi.\n\nFind cheapest fuel points along route\n\nUse a quality fuel additive per recommended mix ratio.\n\nSame with good oil additive.\n( like BestLine Oil Additive )\n\ndo not idle on breaks\n\nhope that helps.","replyToPid":0}
发表于 2021-7-29 14:17:28 来自手机 | 显示全部楼层
{"replyTo":"","text":"cheaper fuel in Texas","replyToPid":0}
发表于 2021-7-29 07:01:51 来自手机 | 显示全部楼层
{"replyTo":"","text":"I took the same route all the way to an area north of Tyler TX before getting off I-20 to go to Waco TX TSC DC","replyToPid":0}
发表于 2021-7-29 06:35:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"I think I would rather do that than go 40. and yeah.\n\nfuel lol","replyToPid":0}
 楼主| 发表于 2021-7-29 07:01:14 来自手机 | 显示全部楼层
27074 发表于 2021-07-28 22:35:34 I think I would rather do that than go 40. and yeah.\n\nfuel lol
","text":"thanks for  the response","replyToPid":438015}
GMT+8, 2026-4-15 17:56 , Processed in 0.074558 second(s), 25 queries .
