查看: 464|回复: 11
Mechanic shop requesting more money days after I left their shop?
 楼主| 发表于 2021-7-27 06:38:50 来自手机 | 显示全部楼层 |阅读模式
{"text":"So the mechanic shop apparently made a mistake while creating the final invoice for the work done on my truck. So they’re saying that some repairs that were previously marked as “no charge” for being covered under warranty were supposed to have been charged. This is the first time going through a scenario like this, and I think they’re probably right in that there was an error while they were creating the final invoice. What do you guys think?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-7-27 07:05:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"you should pay it you 5th wheel tube lubein quęer.","replyToPid":0}
回复 支持 4 反对 4
发表于 2021-7-27 20:54:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"Gay pride 🏳️‍🌈🌈💪","replyToPid":0}
回复 支持 3 反对 3
发表于 2021-7-27 09:26:00 来自手机 | 显示全部楼层
{"replyTo":"","text":"your boyfriend drives for swift. I bet you do also 😏","replyToPid":0}
回复 支持 3 反对 2
 楼主| 发表于 2021-7-27 08:01:51 来自手机 | 显示全部楼层
{"replyToPid":437809,"replyTo":"
1050153 发表于 2021-07-26 23:39:55 I guess all those posts. claiming to know everything 🤔 isn't exactly the truth huh??
","text":"If I don’t know something, I find out. What’s wrong with that? A know-it-all doesn’t ask for help or advice. This isn’t the first time I’ve asked a question. "}
回复 支持 3 反对 2
发表于 2021-7-27 22:19:37 来自手机 | 显示全部楼层
回复 支持 2 反对 2
发表于 2021-7-27 07:39:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"I guess all those posts. claiming to know everything 🤔 isn't exactly the truth huh??","replyToPid":0}
发表于 2021-7-27 08:41:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"If you plan on going back there in the future, pay up. If not, roll on","replyToPid":0}
发表于 2021-7-27 07:10:39 来自手机 | 显示全部楼层
{"replyTo":"","text":"People do make mistakes I worked at a tire shop at one point and I have made the mistake of undercharging and overcharging and I had to make that call and pray that the customer understood. ","replyToPid":0}
发表于 2021-7-27 07:19:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"I put up post earlier about your intelligence 👇👇👇  ...........🤣🤣😭","replyToPid":0}
发表于 2021-7-28 12:49:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"Whenever I have gone into a dealership and had work done that is being billed as warranty work there has always been a clause on the invoice stating the final bill might be adjusted after being submitted for warranty. I have never been rebilled tho. It is possible whoever backed the warranty did not allow everything to be covered. Pay the bill so they don’t put a mechanics lien on your truck. And contact the company that holds your warranty.","replyToPid":0}
发表于 2021-7-27 08:44:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"I’ve had similar issues where I was told it was covered under warranty. Then when paying it was not. If this was a dealership, asks to get it covered under “policy” (that’s just what they call it) its worked for me.","replyToPid":0}
GMT+8, 2026-4-16 04:02 , Processed in 0.190963 second(s), 25 queries .
