查看: 320|回复: 9
new tractor
 楼主| 发表于 2021-7-27 04:35:02 来自手机 | 显示全部楼层 |阅读模式
{"text":"Is it worth buying a tractor new? or old tractor if you are already old and new to the game. Just trying to make some easy bucks. Seems like older gents in industry are putting money away nicely. What's your take?\n ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-7-27 05:48:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"If you’re looking for easy money, your in the wrong place. I’ve been out here for 38 years, and I can’t recall it ever being “easy bucks”. So if you think your going to coast and make money, keep your money in your pocket, and think of something different!","replyToPid":0}
回复 支持 9 反对 0
发表于 2021-7-27 05:38:56 来自手机 | 显示全部楼层
{"replyTo":"","text":"You should go buy a brand new one for well north of 100 thousand dollars. That way there’s still cheap old trucks left for me to buy ","replyToPid":0}
回复 支持 8 反对 0
发表于 2021-7-27 20:47:09 来自手机 | 显示全部楼层
1282290 发表于 2021-07-27 03:36:15 I’m a company driver and this is EZ money
","text":"Probably is since you don’t have to worry about anything but going down the road. ","replyToPid":437837}
禁止发言
发表于 2021-7-27 07:37:41 来自手机 | 显示全部楼层
发表于 2021-7-27 11:36:15 来自手机 | 显示全部楼层
1258332 发表于 2021-07-26 21:48:03 If you’re looking for easy money, your in the wrong place. I’ve been out here for 38 years, and I can’t recall it ever being “easy bucks”. So if you think your going to coast and make money, keep your money in your pocket, and think of something different!
","text":"I’m a company driver and this is EZ money","replyToPid":437787}
发表于 2021-8-6 00:59:07 来自手机 | 显示全部楼层
1258332 发表于 2021-07-27 12:47:09 Probably is since you don’t have to worry about anything but going down the road.
","text":"Amen brother preach to this virgin driver. ","replyToPid":437856}
发表于 2021-8-10 03:48:13 来自手机 | 显示全部楼层
","text":"Then your nit doing the job properly. I bet money you never do a proper inspection. ","replyToPid":437837}
发表于 2021-8-14 06:36:21 来自手机 | 显示全部楼层
{"replyTo":"","text":"pre 2003 for me. always. unless i was building a company fleet with drivers, then and only then would i consider that big bill and emission liability  H2ST.ORG 👍👍","replyToPid":0}
发表于 2021-7-27 10:03:53 来自手机 | 显示全部楼层
{"replyTo":"","text":"Sum 2000 and under don’t require ELD, I went old and can run how I want on log book so u tell me? I say old with a good mechanic.","replyToPid":0}
GMT+8, 2026-4-15 19:56 , Processed in 0.124356 second(s), 24 queries .
