查看: 141|回复: 7
flatbed loads
 楼主| 发表于 2021-7-24 04:37:36 来自手机 | 显示全部楼层 |阅读模式
{"text":"Still can't find flatbed loads all van","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-7-24 06:09:02 来自手机 | 显示全部楼层
{"replyTo":"","text":"https://www.flatloads.com","replyToPid":0}
发表于 2021-7-24 10:24:02 来自手机 | 显示全部楼层
{"replyTo":"","text":"Are you trying to find flatbed loads as an O/O?  I’m confused.  Plenty of flatbed loads ","replyToPid":0}
发表于 2021-7-24 23:14:39 来自手机 | 显示全部楼层
972824 发表于 2021-07-24 02:24:02 Are you trying to find flatbed loads as an O/O?  I’m confused.  Plenty of flatbed loads
","text":"That depends on where your at if you’re anywhere west of Iowa you’re gonna have some problems. ","replyToPid":437343}
发表于 2021-7-25 22:56:19 来自手机 | 显示全部楼层
1281875 发表于 2021-07-24 15:14:39 That depends on where your at if you’re anywhere west of Iowa you’re gonna have some problems.
","text":"This is true.  I am out of Utah and the struggle is real","replyToPid":437384}
发表于 2021-7-25 23:00:45 来自手机 | 显示全部楼层
1047332 发表于 2021-07-23 22:09:02 https://www.flatloads.com
","text":"Do you get good loads off their board?   I have been using Truckstop.com for the better part of a decade","replyToPid":437302}
发表于 2021-7-26 09:49:57 来自手机 | 显示全部楼层
972824 发表于 2021-07-25 15:00:45 Do you get good loads off their board?   I have been using Truckstop.com for the better part of a decade
","text":"Nah, I googled the link for you since you asked. I run a simple dry van trailer for my O/O, I’m a 1099 employee / independent contractor.","replyToPid":437561}
发表于 2021-7-27 07:41:47 来自手机 | 显示全部楼层
{"replyTo":"","text":"that's why I bought a refer the loads are averaging $4.50 per mi with dead head I felt/ seen the loads and rates falling in the flatbed and oversized industry of trucking.","replyToPid":0}
GMT+8, 2026-4-16 08:17 , Processed in 0.112977 second(s), 23 queries .
