查看: 252|回复: 1
2016 Freightliner M2
 楼主| 发表于 2021-7-20 10:13:05 来自手机 | 显示全部楼层 |阅读模式
{"text":"Hey guys, I’m new to truck driving life..So I decided to get my CDL after 3yrs of being fucked over by my drivers…My straight truck goes off automatically after being idle for about 5 to 7 mins. Is this supposed to be normal ? ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-7-20 10:24:36 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Yes, the 5 min engine shut off is very common. You can get that changed at the dealer, but before that, try to make sure if you can bypass it by turning on and setting the cruise control. On some trucks you can raise the RPMs to whatever you want, on others you can’t, but the RPM will sit at 900 with the cruise control set. "}
GMT+8, 2026-4-17 06:07 , Processed in 0.094621 second(s), 25 queries .
