查看: 266|回复: 4
Imagine being this guy…
 楼主| 发表于 2021-7-19 09:07:48 来自手机 | 显示全部楼层 |阅读模式
{"text":"At the TA in Harrisburg. July 18’th. The curtains were closed and it appears they are there for the night. \n\nJust a note. If you drive up behind me with these useless lights that you think you need (and that shine 40’ ahead while at the same time blinding everyone around you) you will get my very bright LED backup lights mounted in the rear of my trailer. \n\nA bit of a rant here I know. But why do these €£+^< drive with those on? No one has heard of hooking them up to a relay on the high beam switch??!! I swear they hook them directly to the ignition switch. \n\nSo, if the driver of this truck sees this post, you should be real proud. \n\nFor those of you who know how to run a high/low beam switch, know how to back up, and drive slowly around truck stop yards and customers, Keep up the good work. ","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":992.0,\"name\":\"\",\"url\":\"\",\"width\":744.0}]","canComment":true,"externalShare":false}
1万
发表于 2021-7-20 14:13:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"I like the idea of lights on the back of your trailer, some drivers apparently need help seeing at night, please help them out when ever you can... and to the other drivers, have some consideration to other drivers and dim your lights (or have them adjusted) instead of blinding us... thanks !!!\n 👍 🇺🇸 🙂","replyToPid":0}
发表于 2021-11-30 21:05:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"And you did not have the bàlls to tell him anything . Just post it here.  Sound like a real tough guy ","replyToPid":0}
发表于 2021-7-20 22:27:39 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Spray paint works wonders 😁\nalso I hang LED lights on the side of the trailer if needed for better visibility at night, they're not permanent so I can remove them easily when done backing into a spot"}
1万
发表于 2021-7-20 19:31:02 来自手机 | 显示全部楼层
{"replyTo":"","text":"come on drivers !!! \ncan't you see all that fog !!!","replyToPid":0}
GMT+8, 2026-2-8 02:18 , Processed in 0.066104 second(s), 24 queries .
