查看: 521|回复: 14
failed drug screen
 楼主| 发表于 2021-7-18 00:34:30 来自手机 | 显示全部楼层 |阅读模式
{"text":"I was wondering if anyone had been through or knew of anyone who failed a DOT drug screen? A good friend of mine just went home and his friends had a party for him...well needless to say, he partied then got a random. He's not sure if he'll pass. Is there anyone that knows what could the treatment be for this besides the suspension, treatment program, ect? How long will it be before he can return to driving safely otr? He would never do that while driving and isn't a partier, just messed up at the worst possible time! Thanks for any info in advance!","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-7-18 01:54:00 来自手机 | 显示全部楼层
{"replyTo":"","text":"that's great drug users need to be off the road","replyToPid":0}
回复 支持 7 反对 2
发表于 2021-7-18 00:53:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"Don't do drugs easy solution!👎","replyToPid":0}
回复 支持 9 反对 0
发表于 2021-7-18 08:52:58 来自手机 | 显示全部楼层
{"replyTo":"","text":"No company will hire you again…","replyToPid":0}
回复 支持 4 反对 2
发表于 2021-7-18 01:50:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"Has to complete a DOT approved drug treatment program at his own expense. There is a Return to Duty process that has to be followed.","replyToPid":0}
回复 支持 6 反对 0
发表于 2021-7-18 00:56:31 来自手机 | 显示全部楼层
{"replyTo":"","text":"He will have to go to rehab as a drug addiction plus he will loose his license till he complete it . Afterwards he will be test 6 times in 12 mo to plus have a hard time getting hired. . And over the next 60 mo he will be required to be tested every 3 mo as well. ","replyToPid":0}
1万
发表于 2021-7-18 00:41:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"does he like his job ???","replyToPid":0}
发表于 2021-7-19 01:34:40 来自手机 | 显示全部楼层
649429 发表于 2021-07-18 00:52:58 No company will hire you again…
","text":"Not true. Buddy of mine had a refusal on his record. He was back in the seat after a month.","replyToPid":436422}
发表于 2021-7-18 00:38:56 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"buy  a whizzinator! don't pěe if not sure"}
 楼主| 发表于 2021-7-18 23:21:33 来自手机 | 显示全部楼层
936953 发表于 2021-07-17 17:50:10 Has to complete a DOT approved drug treatment program at his own expense. There is a Return to Duty process that has to be followed.
","text":"any idea on the time frame for the treatment program? Thanks for reading and answering with intelligence. I guess some people have never made mistakes and are perfect. Thanks again","replyToPid":436400}
发表于 2021-7-19 00:30:33 来自手机 | 显示全部楼层
1110303 发表于 2021-07-18 15:21:33 any idea on the time frame for the treatment program? Thanks for reading and answering with intelligence. I guess some people have never made mistakes and are perfect. Thanks again
","text":"No we know not to do drugs so we can keep our license. He made a monumental misstep .   Our industry is hard and requires you to be absolutely dedicated to be clean and no alcohol in your system. We can not even have mouth wash that has alcohol in it.   ","replyToPid":436484}
GMT+8, 2026-2-9 09:12 , Processed in 0.065815 second(s), 24 queries .
