查看: 122|回复: 7
stretch
 楼主| 发表于 2021-7-17 01:16:37 来自手机 | 显示全部楼层 |阅读模式
{"text":"Im thinking about stretching 97 classic.\nAny pros or Cons?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-7-17 02:11:20 来自手机 | 显示全部楼层
957369 发表于 2021-07-16 17:47:40 They look good but if you do a lot of city work the extra length can cause so difficulty’s. Plus make sure you use a shop who does this a lot. Because. I’ve seen them done wrong and them breaking while making hard turns or being in a bind .
","text":"everyone has to start somewhere. How about you look at their methods.","replyToPid":436237}
发表于 2021-7-17 03:19:25 来自手机 | 显示全部楼层
{"replyTo":"","text":"you will pay good money to make your life more difficult in every city every dock","replyToPid":0}
禁止发言
发表于 2021-7-17 03:25:38 来自手机 | 显示全部楼层
发表于 2021-7-17 01:47:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"They look good but if you do a lot of city work the extra length can cause so difficulty’s. Plus make sure you use a shop who does this a lot. Because. I’ve seen them done wrong and them breaking while making hard turns or being in a bind . ","replyToPid":0}
发表于 2021-7-17 03:50:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"Add a dump valve to your rear trailer axle if you do.  Makes backing easier!","replyToPid":0}
发表于 2021-7-17 09:01:53 来自手机 | 显示全部楼层
{"replyTo":"","text":"As previously stated, it must be done right. If you are going to do what you are doing now, you already know whether or not that length will work.","replyToPid":0}
 楼主| 发表于 2021-7-19 01:17:24 来自手机 | 显示全部楼层
{"replyTo":"","text":"Thanks for the input. I think I'll save myself the money and they headaches","replyToPid":0}
GMT+8, 2026-2-9 14:32 , Processed in 0.056527 second(s), 24 queries .
