查看: 181|回复: 6
Just starting flatbed.
 楼主| 发表于 2021-7-16 23:22:28 来自手机 | 显示全部楼层 |阅读模式
{"text":"I just completed week 1 with my trainer. I am late to this profession (56). Something I always wanted to do. I retired from the US Army in 2003 got my CDL that year but did not drive. Took other jobs because my son was only 4 years old. I retired from the USPS this past April and decided to give flatbed trucking a shot.","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
禁止发言
发表于 2021-7-16 23:39:08 来自手机 | 显示全部楼层
回复 支持 7 反对 0
发表于 2021-7-17 04:12:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"There is bunch of good videos on YouTube. On proper securement. There is one by Indiana DOT. Officer explain what they look for. During inspection.  Remember Flatbed has more  things Dot can fail you for.","replyToPid":0}
发表于 2021-7-17 08:01:05 来自手机 | 显示全部楼层
{"replyTo":"","text":"Take your time, double check, triple check, always check. Just take your time don’t get in a hurry and be willing to learn something new from whoever is offering a tip or advice ","replyToPid":0}
发表于 2021-7-17 12:06:44 来自手机 | 显示全部楼层
{"replyTo":"","text":"There is no such thing as \"over\" securing. Always be looking back at your load to see if straps or chains are lose. After you tarp, watch the load. The wind will show you exactly where you need another bungee. Take your time. Never be afraid to ask questions, or for help. ","replyToPid":0}
发表于 2021-7-17 11:36:43 来自手机 | 显示全部楼层
{"replyTo":"","text":"welcome to flatbedding. Old Marine and the others give some valuable advice. T ake your time securing, if you do not know what to do, do not be shy to ask for advice. Remember DOT securement regulations are just the minimum required securement. I try to X-Strap the front of the load or build a false bulkhead whenever possible. Tier strap or belly wrap whenever you can. Never skip a safety check and, check your load every time you stop, things have a way of coming loose. And, do not be shy to tell the loader how you want your trailer loaded, in the end you are responsible for that load, not the loader. One more piece of advice, buy a sturdy ladder.","replyToPid":0}
发表于 2021-7-25 19:02:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"Best of luck. Thank you for your Service.","replyToPid":0}
GMT+8, 2026-3-22 13:57 , Processed in 0.076173 second(s), 24 queries .
