查看: 376|回复: 17
How to maximize ur driving time Through e log
 楼主| 发表于 2021-7-16 09:11:20 来自手机 | 显示全部楼层 |阅读模式
{"text":"Can anybody help me or give me a better option. On how to run without losing drive time ?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-7-16 10:39:01 来自手机 | 显示全部楼层
{"replyTo":"","text":"Just run at the most 8 hours and 45 mins a day. You can basically run as long as you want off of them recaps ","replyToPid":0}
回复 支持 4 反对 1
发表于 2021-7-16 11:24:47 来自手机 | 显示全部楼层
{"replyTo":"","text":"Another fake troll 😈….. pis off of tp","replyToPid":436092}
发表于 2021-7-16 11:33:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"Every minute counts toward your daily and for the week to maximize your miles. Try combining your 15 min. of Pretrip/MidTrip/PostTrip times with fueling. Use Toll roads to save time and miles (not money) because the time and miles equal $$$ (cost and benefit) Utilize software for trip planning and routing to ensure your chosen route and any re-route is the fastest way to get to your destination. Consider, speed limits, hills, road conditions, traffic conditions, special events in cities, which are all time-consuming and restrict your daily progress for maximizing miles. Do not have a bad habit of sleeping past your 10-hour break, and keep the 30-minute break tight as well. If a trip is pressed for time then utilize your split sleeper options 8/2 & 7/3 but do not add the 30-minute break also since the 2 or 3 hours will cover it. You can go at least 3 to 4 miles over the posted speed limits without getting a ticket. (Speed = Distance / Time) I hope that will help you a bit.","replyToPid":0}
发表于 2021-7-16 11:28:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"When you pull in to shipping/receiving spot go into yard move and docking trailer also when pulling out","replyToPid":0}
发表于 2021-7-17 03:34:45 来自手机 | 显示全部楼层
1047332 发表于 2021-07-16 03:33:49 Every minute counts toward your daily and for the week to maximize your miles. Try combining your 15 min. of Pretrip/MidTrip/PostTrip times with fueling. Use Toll roads to save time and miles (not money) because the time and miles equal $$$ (cost and benefit) Utilize software for trip planning and routing to ensure your chosen route and any re-route is the fastest way to get to your destination. Consider, speed limits, hills, road conditions, traffic conditions, special events in cities, which are all time-consuming and restrict your daily progress for maximizing miles. Do not have a bad habit of sleeping past your 10-hour break, and keep the 30-minute break tight as well. If a trip is pressed for time then utilize your split sleeper options 8/2 & 7/3 but do not add the 30-minute break also since the 2 or 3 hours will cover it. You can go at least 3 to 4 miles over the posted speed limits without getting a ticket. (Speed = Distance / Time) I hope that will help you a bit.
","text":"Time is money, but not always. Driving fast or always using the toll roads isn’t always necessary and I’d argue that for most people it’s wasteful and hurting your bottomline. Scenarios where it would be necessary to do what you suggest would be running on a dedicated route where you must drive 70 mph or else you won’t make it, but that’s rarely the case for most drivers.","replyToPid":436103}
发表于 2021-7-16 11:15:51 来自手机 | 显示全部楼层
{"replyTo":"","text":"😂","replyToPid":0}
发表于 2021-7-17 07:08:48 来自手机 | 显示全部楼层
{"replyTo":"","text":"try one of the shady Russian companies in Chicago they hack the eld and give you all the time you want","replyToPid":0}
发表于 2021-7-17 03:22:18 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Make use of the “yard move” if available instead of actual drive time, this way you can drive more for the day. However, “yard move” still counts against your 70, so make sure you put it back on sleeper break as soon as you’re done with it. You can use yard move pretty much anywhere that is not a public road, but check with your company as they may have their own (stricter) policy.\n\nIf you can use PC, use it, but legally of course. So take advantage of it because it won’t count towards your 70 at all. Also, don’t abuse it because it can become a problem if a DOT were to inspect your logs. Unless you’re on time off, you shouldn’t be using PC every day. Maybe 1-2 times per week is okay, and save your receipts for further proof like you went to Walmart or McDonald’s, etc. \n\nWhen you’re backing up, put the truck on sleeper break. It actually doesn’t matter how fast you drive in reverse at least on the Omnitracs device. You can do 10 mph and it won’t change you to drive time, but then again, nobody is going to be reversing that fast. \n\nWhenever possible and practical, move the truck under 4 mph for short distances. There’s no need to put the truck on yard move or drive time if you’re moving just a bit, say, within a small shipper/receiver. And of course, be mindful of others, so if there’s a lot of traffic, you don’t want to be delaying everyone while you drive at 4 mph. "}
发表于 2021-7-17 06:34:51 来自手机 | 显示全部楼层
279311 发表于 2021-07-16 19:34:45 Time is money, but not always. Driving fast or always using the toll roads isn’t always necessary and I’d argue that for most people it’s wasteful and hurting your bottomline. Scenarios where it would be necessary to do what you suggest would be running on a dedicated route where you must drive 70 mph or else you won’t make it, but that’s rarely the case for most drivers.
","text":"Oh yeah, I did forget to think about the loads I run. Not going to be the same for a new company guy. Yes, you are 100% correct, as my runs are always dispatched above the 65 mph avg. But, it is still good knowledge for time management when that would be priority over $ consumption. Good call on catching that! 😎👍","replyToPid":436251}
发表于 2021-7-17 03:11:54 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"@ Vampire Kid\n\nBad idea. That won’t give you the most driving hrs in a week. What it will do is give you the ability to run every day without running out of hrs, and realistically it’s not driving 8:45 hrs per day, it’s more like driving 8:10 hrs per day because you have to log daily inspections, fuel, shipper/receiver, etc. The method you speak of has its usage like for team drivers where one driver should always have drive time so you run him at 8:45 “on duty” hrs per day."}
 楼主| 发表于 2021-7-16 13:08:21 来自手机 | 显示全部楼层
","text":"Ok so if u do the 8/2 or 7/3 how much additional drive time u get ? ","replyToPid":436103}
发表于 2021-7-16 19:24:21 来自手机 | 显示全部楼层
1249499 发表于 2021-07-16 05:08:21 Ok so if u do the 8/2 or 7/3 how much additional drive time u get ?
","text":"If you have a liad due in 2 days that is really tight (48 hours) and you do one of the split sleeper berth options with the larger part of either 8 or 7 in the sleeper and the smaller part of 2 or 3 on “Off Duty” ...then you will save yourself 1 hour (a half hour for each split sleeper period) total before arrival to destination in order to be on time. It does not save on driving hours but it saves on time management to deliver. You just need to be careful that the option works to the advantage of having the 2 or 3 hours off when waiting in dock on arrival, that way you are ready to roll after you are empty and forced to leave property and go puck up the next load.\n\nNot recommended to do split slepper all the time because it will wear your a** out!\n\nLike the old log book of running 5 / 4 / 5 / all the way to 70, before log changes after 2003.\n\nAlso on that, Use a melatonin pill to get good sleep while in the split sleeper. Dont over do your energy shots and caffeine when awake. Sometimes good to do a couple push ups or sit ups or jog in place to wake up.","replyToPid":436136}
GMT+8, 2026-3-21 07:35 , Processed in 0.121329 second(s), 24 queries .
