查看: 187|回复: 7
flat bed / dry & refer
 楼主| 发表于 2021-7-13 23:43:25 来自手机 | 显示全部楼层 |阅读模式
{"text":"I need to ask if driving flat bed is any different then doing dry/ refer? I was offered a job making $23.00 an hour for a company here in Florida and I'm not sure if that's a good offer or not. The company said that I would be running from Orlando/Jacksonville to Miami area..please help..thank you ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-7-14 00:39:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"just keep in mind your gonna have to climb up to strap  and unstrap / tarp your   load all the time .","replyToPid":0}
发表于 2021-7-15 17:04:53 来自手机 | 显示全部楼层
{"replyTo":"","text":"Flat bedding is harder more physical, and you need trained if you've never done it. it's hard tarping loads in wind and heat. and throwing straps over and fastening down properly takes time and must be done right. as well as using chains and binders. You also have different types of tarps. wood, steel usage are different in lengths widths etc... !   a ladder, coil racks, and 2x6s and bungies and corner protectors are required. smoke tarps too! which used to cover just front of loads to protect from exhaust heat, unless exhaust under truck. Anyway 23.00 is not enough for working and driving!","replyToPid":0}
发表于 2021-7-15 15:57:22 来自手机 | 显示全部楼层
{"replyTo":"","text":"if your new to flatbed, (I've never done it) I would suggest prioritize finding a company that property trains you over how much you are paid. Once you have the knowledge and experience you can put in your 2 weeks, get the raise you desire or move to a high paying company.","replyToPid":0}
发表于 2021-7-14 03:03:31 来自手机 | 显示全部楼层
{"replyTo":"","text":"Refer usually pays more than dry. With Refer you'll must likely have to get a truck wash between each load also you will be fueling your refer to keep it running and a lot of shippers/receivers will not let you in the gate if it's not 1/2 to 3/4 full. Flat bed pays usually pays more than either of these but as mentioned it you also have to keep in mind that you'll be tarping/ unstrapping your load. More money but also more work. It all depends on what your goals are and how hard you want to work to achieve them. With that said $23 hr seems on the low end for the work you'll be putting in.","replyToPid":0}
 楼主| 发表于 2021-7-14 02:15:26 来自手机 | 显示全部楼层
766797 发表于 2021-07-13 17:59:57 low offer  on FB you should be around 30% of gross or 330$ a day.
","text":"ok ty","replyToPid":435698}
 楼主| 发表于 2021-7-14 02:15:19 来自手机 | 显示全部楼层
524227 发表于 2021-07-13 16:39:17 just keep in mind your gonna have to climb up to strap  and unstrap / tarp your   load all the time .
","text":"ok ty","replyToPid":435682}
 楼主| 发表于 2021-7-14 03:08:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"thank you for your help, it seems like I made a lot more by driving OTR but I wasn't sure now a days what the pay was","replyToPid":0}
GMT+8, 2026-2-9 14:32 , Processed in 0.051920 second(s), 24 queries .
