查看: 207|回复: 7
Morning Drivers!
 楼主| 发表于 2021-7-11 21:22:48 来自手机 | 显示全部楼层 |阅读模式
{"text":"Good morning drivers.  Headed from Nebraska to PA.  There's a couple roll overs out here on I-80 this morning ( most likely happened overnight and haven't been moved) and plenty of construction.  Stay safe out here. ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
 楼主| 发表于 2021-7-11 22:19:20 来自手机 | 显示全部楼层
thanks for the heads up be safe and alot of construction in PA. Be safe
{"replyToPid":435358,"replyTo":"
289718 发表于 2021-07-11 14:08:10 thanks for the heads up be safe and alot of construction in PA. Be safe
","text":"Doing a 30 min. Absolutely. Stay safe also."}
发表于 2021-7-11 21:28:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"have a safe trip","replyToPid":0}
发表于 2021-7-11 21:32:54 来自手机 | 显示全部楼层
{"replyTo":"","text":"thank you 😊","replyToPid":435350}
 楼主| 发表于 2021-7-11 21:29:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"Thanks! You also.","replyToPid":435348}
发表于 2021-7-11 22:15:52 来自手机 | 显示全部楼层
{"replyTo":"","text":"Good morning ","replyToPid":0}
发表于 2021-7-11 22:08:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"thanks for the heads up be safe and alot of construction in PA. Be safe","replyToPid":0}
发表于 2021-7-11 21:40:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"thank u for update","replyToPid":0}
GMT+8, 2026-2-9 17:45 , Processed in 0.055589 second(s), 24 queries .
