查看: 683|回复: 23
What’s the most reliable truck and engine out now ?
 楼主| 发表于 2021-7-10 22:23:31 来自手机 | 显示全部楼层 |阅读模式
{"text":"?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
1万
发表于 2021-7-10 22:26:47 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"everyone is going to have a different opinion...\nmy opinion is the most reliable engine is one before emissions and DEF...\na rebuilt old one... \n 🙂 🇺🇸 👍"}
回复 支持 8 反对 0
发表于 2021-7-11 01:19:31 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"IMO Fully deleted X15 and properly tuned with supporting mods for the tune and delete. Some say CAT c15 c16 or a marine engine is best. I think they all great if properly deleted and properly tuned and maintained.  Can’t say anything for Detroit.. never worked on one or drive a truck with one. \n\nNow as far as chassis go, you can’t go wrong with a 389, 379 peterbilt or a Kenny W9\n\nThe older the better , less electronic junk "}
回复 支持 6 反对 0
发表于 2021-7-11 17:06:56 来自手机 | 显示全部楼层
{"replyTo":"","text":"+16304748633","replyToPid":0}
回复 支持 0 反对 4
发表于 2021-7-10 23:03:54 来自手机 | 显示全部楼层
{"replyTo":"","text":"Ford F-150 lightning with the AC permanent-magnet electric motor at 563hp??🤷🏻‍♂️","replyToPid":0}
回复 支持 2 反对 2
发表于 2021-7-11 10:55:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"I think if you want to find your answer you will need to ask several different mechanics across the nation and maybe a couple of specialty shops like Pittsburgh Power and Fitzgerald glider kits. When I ask that same question, so far, the most common answer for the best is the Cummins ISX and the worst is Paccar.","replyToPid":0}
回复 支持 2 反对 2
发表于 2021-7-12 23:07:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"Volvo","replyToPid":0}
回复 支持 0 反对 3
1万
发表于 2021-7-10 23:16:38 来自手机 | 显示全部楼层
1088913 发表于 2021-07-10 15:03:54 Ford F-150 lightning with the AC permanent-magnet electric motor at 563hp??🤷🏻‍♂️
","text":"are we talking about motors or engines ???  🙂 🇺🇸 👍","replyToPid":435213}
1万
发表于 2021-7-10 22:55:21 来自手机 | 显示全部楼层
{"replyTo":"","text":"it's tough to answer the question because we need more information, what type of operation is this truck going to be working in ? all manufactories make many different models and one might be more reliable than the other...","replyToPid":0}
发表于 2021-7-14 04:45:45 来自手机 | 显示全部楼层
766797 发表于 2021-07-13 18:05:11 and we talking oem dealer not \"certified \" even good shop like PP will kick you out 🙃‼️🤔
","text":"I have my truck worked on at Freightliner/Western Star dealer(s). Never been an issue. ","replyToPid":435701}
发表于 2021-7-13 23:43:59 来自手机 | 显示全部楼层
766797 发表于 2021-07-11 05:40:59 CAT 3406B tuned DOWN TO 537 hp to the ground on dino
","text":"And is suppose it get 8.0 mpg? Lol ","replyToPid":435323}
 楼主| 发表于 2021-7-10 22:34:43 来自手机 | 显示全部楼层
1031233 发表于 2021-07-10 14:26:47 everyone is going to have a different opinion...\nmy opinion is the most reliable engine is one before emissions and DEF...\na rebuilt old one... \n 🙂 🇺🇸 👍
","text":"I’ve heard that a lot, you kinda afraid of them, some say once you rebuild there’re never the same ","replyToPid":435202}
发表于 2021-7-11 00:10:43 来自手机 | 显示全部楼层
{"replyTo":"","text":"2015. DD15. Full delete. 785000 miles. 19052 hours. Changed turbo this year. That’s it. Oil samples indicate no wear. Oil changed at 62000 miles since new. ","replyToPid":0}
发表于 2021-7-11 03:27:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"...","replyToPid":0}
GMT+8, 2026-4-17 18:16 , Processed in 0.106281 second(s), 24 queries .
