查看: 124|回复: 2
New Cascadia (2019+) headlights?
 楼主| 发表于 2021-7-3 12:26:54 来自手机 | 显示全部楼层 |阅读模式
{"text":"So I’ve noticed that this style of headlights only have one plug in the back. What happens when there’s a lighting problem inside the headlight case? Are they serviceable? They look like LED lights, but it would sck if something stops working and I were to need to replace the entire headlight case. ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
 楼主| 发表于 2021-7-4 02:03:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"So I watched a YouTube video where it showed that some components can be removed. The repair looked simple, fortunately. ","replyToPid":0}
发表于 2021-7-3 12:56:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"You can buy the individual components, but they’re not exactly easy to swap. You shouldn’t need to but it is possible.","replyToPid":0}
GMT+8, 2026-4-17 19:54 , Processed in 0.081788 second(s), 24 queries .
