查看: 137|回复: 4
Running 30 in AR going NORTH 🛠😔
 楼主| 发表于 2021-7-3 09:26:22 来自手机 | 显示全部楼层 |阅读模式
{"text":"Out of TX and about 15 miles before the Love’s in Malvern, AR some real cool flatbed trucker thought it be bright idea to ram into my truck…and the passenger side where my woman was sitting 🤬!!! This is what happened.. I’m already in the right lane…I flashed him over… he didn’t move, mr. I don’t do what you tell me to do attitude…… SO I proceeded my pass and he goes faster, pulls his ebrake making a tantrum then pushes his way through, damaging the whole passenger side of my truck and took off!! He was ballin 90mph and hid somewhere. If anyone was able to see him or has cam footage for me that would be great, our dash cam just quit on us too..OR if you’re mr. cool guy yourself hit me up! Let’s be men! Or learn the HARDWAY😃🔥🐍☝️","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-7-3 09:30:56 来自手机 | 显示全部楼层
{"replyTo":"","text":"Oh that a sad to 😔😔","replyToPid":0}
 楼主| 发表于 2021-7-3 10:09:12 来自手机 | 显示全部楼层
279311 发表于 2021-07-03 02:07:50 Dash cams stop working because the memory cards get toast from the heat. I remember having many problems with that. Garmin dash cams will tell you when you need to get a new memory card.
","text":"Thanks for the tip","replyToPid":433658}
发表于 2021-7-3 10:07:50 来自手机 | 显示全部楼层
{"replyTo":"","text":"Dash cams stop working because the memory cards get toast from the heat. I remember having many problems with that. Garmin dash cams will tell you when you need to get a new memory card.","replyToPid":0}
发表于 2021-7-3 11:50:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"Cobra and Nexar dashcam are very good for tolerance for the heat from the sunlight, I run mine 24 hours and issues, Cobra is a bit spendy but we'll worth it","replyToPid":0}
GMT+8, 2026-2-8 06:49 , Processed in 0.061791 second(s), 24 queries .
