查看: 179|回复: 5
2015 cascada
 楼主| 发表于 2021-7-2 14:15:40 来自手机 | 显示全部楼层 |阅读模式
{"text":"Where’s the cb atenna located???","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-7-3 07:31:32 来自手机 | 显示全部楼层
929136 发表于 2021-07-02 14:41:26 That model cascadia does not have antenna connections. The company was trying something new. You should see the coax cable on the dash, the whole truck is the antenna,
","text":"probably don't get out more than 2 feet with all that plastic","replyToPid":433547}
发表于 2021-7-2 22:41:26 来自手机 | 显示全部楼层
{"replyTo":"","text":"That model cascadia does not have antenna connections. The company was trying something new. You should see the coax cable on the dash, the whole truck is the antenna,","replyToPid":0}
发表于 2021-7-2 21:32:06 来自手机 | 显示全部楼层
{"replyTo":"","text":"It’s located on Google Maps, green means go, amber means caution, red means Swift did it again.","replyToPid":0}
发表于 2021-8-25 11:02:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"on the mirrors","replyToPid":0}
发表于 2021-7-2 14:43:52 来自手机 | 显示全部楼层
{"replyTo":"","text":"You can look for it on your phone ❤️","replyToPid":0}
GMT+8, 2026-4-15 15:47 , Processed in 0.178383 second(s), 24 queries .
