查看: 331|回复: 14
All bad for
 楼主| 发表于 2019-6-7 21:22:28 来自手机 | 显示全部楼层 |阅读模式
{"text":null,"videos":"[]","link":"{}","pics":"[{\"description\":\"All bad for me but the good thing I’m alive. jackknife \",\"height\":1000.0,\"name\":\"\",\"url\":\"\",\"width\":750.0}]","canComment":true}
 楼主| 发表于 2019-6-7 22:38:38 来自手机 | 显示全部楼层
332591 发表于 2019-06-07 14:12:09  driver glad you good I hate to see this... strap ya boots up dust yourself off get back on the saddle this will probably make you a better driver if you choose to continue to drive
","text":"It will take more than a jackknifes to make me stop driving I’m just glad no one got hurt or hit nobody or anything ","replyToPid":58396}
发表于 2019-6-7 21:27:44 来自手机 | 显示全部楼层
{"replyTo":"","text":"Dats wat counts driver! These machines are replaceable! ","replyToPid":58312}
发表于 2019-6-7 22:13:19 来自手机 | 显示全部楼层
344441 发表于 2019-06-07 13:27:44 Dats wat counts driver! These machines are replaceable!
","text":"This is truuuu!!!!","replyToPid":58318}
发表于 2019-6-7 22:14:07 来自手机 | 显示全部楼层
607385 发表于 2019-06-07 13:26:40 im so sorry, I'm glad you're okay thou,  that's important!!!
","text":"Most definitely the most important thing is that driver OK ","replyToPid":58315}
发表于 2019-6-7 22:12:09 来自手机 | 显示全部楼层
{"replyTo":"","text":" driver glad you good I hate to see this... strap ya boots up dust yourself off get back on the saddle this will probably make you a better driver if you choose to continue to drive ","replyToPid":0}
 楼主| 发表于 2019-6-7 21:25:05 来自手机 | 显示全部楼层
707101 发表于 2019-06-07 13:24:06 whoops! That isn't you, is it? Hope you're okay!!!
","text":"Yea I’m good thx","replyToPid":58310}
发表于 2019-6-10 23:58:24 来自手机 | 显示全部楼层
451581 发表于 2019-06-10 12:44:03 I don’t think it was a mistake it was that I was light on back so when I hit a bump my rear tires came of the floor so when land back to the floor it fishtailed that when was all bad plus the rain did not help
","text":"You’ve hit bumps while empty I’m sure. Do you usually make your trailer go airborne, Did you wreck then? Probably not. So let’s say you were going to fast for conditions, speed is awesome but it’s the main cause of accidents next to faulty equipment ","replyToPid":62126}
发表于 2019-6-7 21:24:06 来自手机 | 显示全部楼层
{"replyTo":"","text":"whoops! That isn't you, is it? Hope you're okay!!!","replyToPid":0}
发表于 2019-6-7 21:25:09 来自手机 | 显示全部楼层
","text":"it is you... glad your okay! my phone was slow loading up...","replyToPid":58310}
发表于 2019-6-7 22:11:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"**** driver glad you good I hate to see this... strap ya boots up dust yourself off get back on the saddle this will probably make you a better driver if you choose to continue to drive ","replyToPid":0}
GMT+8, 2026-3-21 15:13 , Processed in 0.075431 second(s), 24 queries .
