查看: 173|回复: 8
Splitter (18 speed) grinding
 楼主| 发表于 2021-6-29 07:10:40 来自手机 | 显示全部楼层 |阅读模式
{"text":"So I have an 18 speed and shifting direct (1,2,3,4,5,6,7,8) at any RPM’s shifts fine. But when I’m loaded and driving it like a 13 speed as in when I flip my range selector up from 4 to 5 then split to 5Hi to 6lo it grinds and I have to rev it up so it goes into gear. It does this anytime I go from the hi side of the gear while upshifting to the next gear on the low side. Was reading about it and they said the synchronizer might be bad. Has anyone else had this problem and what was the solution? Truck is in the shop no getting turbo replaced and asked them to check out the back side of the transmission. Is there any other info I could possibly tell the mechanic that might help him find the problem if they overlook something?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-6-29 07:25:41 来自手机 | 显示全部楼层
1272718 发表于 2021-06-28 23:20:00 need ch.inese. grease make it go
","text":"Cuss u acussme ","replyToPid":432430}
发表于 2021-6-29 07:20:00 来自手机 | 显示全部楼层
{"replyTo":"","text":"need ch.inese. grease make it go","replyToPid":0}
禁止发言
发表于 2021-6-29 07:35:16 来自手机 | 显示全部楼层
发表于 2021-6-29 12:40:05 来自手机 | 显示全部楼层
{"replyTo":"","text":"You have, most likely a loose pin in the synchronizer in the back box, possibly even a broken pin. The pins have steps on them that match closely with the stepped holes they ride in on the synchronizer ring. This happens a lot. It only takes a loose pin to drop out of line with the ring a few thousands and they hang up and grind. I am pretty sure this is your problem. Also look for driveline problems as driveline vibrations is the major cause of loose or broken syncro pins.","replyToPid":0}
发表于 2021-6-29 08:55:26 来自手机 | 显示全部楼层
{"replyTo":"","text":"Like old marine said check air psi. Should be 80-100. If that checks out then their going to have to drop the tranny. Can’t just pull the back bell housing for that. She’s gotta come out. ","replyToPid":0}
发表于 2021-6-29 13:05:14 来自手机 | 显示全部楼层
{"replyTo":"","text":"Try splitting down after you move the shifter. so basically go from 5 hi to 6 hi then drop to 6 lo that’s how some of the ones I’ve driven are ","replyToPid":0}
发表于 2021-7-22 04:01:32 来自手机 | 显示全部楼层
{"replyTo":"","text":"How did you make out? Got it fixed and working properly now?","replyToPid":0}
 楼主| 发表于 2021-7-22 06:48:25 来自手机 | 显示全部楼层
267931 发表于 2021-07-21 20:01:32 How did you make out? Got it fixed and working properly now?
","text":"Needed a new synchronizer. Works like it’s supposed to now!","replyToPid":436936}
GMT+8, 2026-2-9 11:15 , Processed in 0.078093 second(s), 24 queries .
