查看: 338|回复: 23
over weight
 楼主| 发表于 2021-6-26 20:19:23 来自手机 | 显示全部楼层 |阅读模式
{"text":"If I'm 525 kg overweight will alberta dot bother me ? thanks ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
1万
发表于 2021-6-26 22:10:41 来自手机 | 显示全部楼层
that's all they registered the truck for.
{"replyToPid":431820,"replyTo":"
1140767 发表于 2021-06-26 14:06:11 that's all they registered the truck for.
","text":"ok, I'm sorry, I didn't get it...\nI was beginning to wonder if they were pulling a snowmobile trailer with their minivan. 🙂 and had too many sleds on it..."}
1万
发表于 2021-6-26 21:51:36 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"it is very hard to make out what you are talking about... what language do they speak in Alberta ??? must not be English... you said you were 525 kgs over, yet you said that your gross on the 2 axles was 11735 kgs which is 25871 lbs. \nI don't get it ???\n\nthis is 90,000 \nnot 90.000 \nuse a comma not a period\n\nit's Canada, when the axle breaks you know your overloaded... 🙂"}
发表于 2021-6-27 06:37:54 来自手机 | 显示全部楼层
{"replyTo":"","text":"I'm available for hookup 😋❣️","replyToPid":0}
发表于 2021-6-26 20:23:45 来自手机 | 显示全部楼层
{"replyTo":"","text":" 4 axale or 3 axle dont have you gross weight","replyToPid":0}
发表于 2021-6-26 20:25:35 来自手机 | 显示全部楼层
1270826 发表于 2021-06-26 12:23:45  4 axale or 3 axle dont have you gross weight
","text":"Or b trains ","replyToPid":431795}
 楼主| 发表于 2021-6-26 20:26:35 来自手机 | 显示全部楼层
","text":"2 axal  11 735 gross","replyToPid":431795}
发表于 2021-6-26 20:29:56 来自手机 | 显示全部楼层
{"replyTo":"","text":"If 2 ax 90.000 lbs depence what kind of guy you will hit","replyToPid":431796}
发表于 2021-6-26 20:32:29 来自手机 | 显示全部楼层
1270826 发表于 2021-06-26 12:29:56 If 2 ax 90.000 lbs depence what kind of guy you will hit
","text":"If 2ax past 90.000 lbs lile 1000 lbs well good luck you shud have 3 ax","replyToPid":431799}
发表于 2021-6-26 20:39:28 来自手机 | 显示全部楼层
1270826 发表于 2021-06-26 12:32:29 If 2ax past 90.000 lbs lile 1000 lbs well good luck you shud have 3 ax
","text":"Got you gross weiht 90.000´bs load max is 50.0000lbs ","replyToPid":431801}
发表于 2021-6-26 20:39:56 来自手机 | 显示全部楼层
1270826 发表于 2021-06-26 12:39:28 Got you gross weiht 90.000´bs load max is 50.0000lbs
","text":"Me be be will do something ","replyToPid":431804}
 楼主| 发表于 2021-6-26 20:49:37 来自手机 | 显示全部楼层
1270826 发表于 2021-06-26 12:39:56 Me be be will do something
","text":"k thanks will take stuff out of the truck.","replyToPid":431805}
发表于 2021-6-26 21:38:42 来自手机 | 显示全部楼层
1140767 发表于 2021-06-26 12:49:37 k thanks will take stuff out of the truck.
","text":"Good luck","replyToPid":431809}
GMT+8, 2026-4-16 08:17 , Processed in 0.195684 second(s), 24 queries .
