查看: 476|回复: 25
A p u try pack still good or not in california
 楼主| 发表于 2021-6-25 08:06:11 来自手机 | 显示全部楼层 |阅读模式
发表于 2021-6-27 06:50:23 来自手机 | 显示全部楼层
1266753 发表于 2021-06-26 22:38:43 I'm available for hookup 😋❣️
","text":"me and you and a bucket of KFC baby","replyToPid":431932}
 楼主| 发表于 2021-6-25 08:17:58 来自手机 | 显示全部楼层
1269260 发表于 2021-06-25 00:17:10 Ok tank you because  i tink they change law over there
","text":"Got thermo king evolution","replyToPid":431470}
 楼主| 发表于 2021-6-25 08:17:10 来自手机 | 显示全部楼层
279311 发表于 2021-06-25 00:14:12 I have never heard a CA DOT officer check if the APU complies with their regulations. I think the TK Tripac Evolution APU does come with some sort of DPF, while the regular Tripac does not. I personally wouldn’t lose any sleep over using old model APUs.
","text":"Ok tank you because  i tink they change law over there ","replyToPid":431469}
 楼主| 发表于 2021-6-26 00:02:16 来自手机 | 显示全部楼层
279311 发表于 2021-06-25 15:06:52 In CA the law generally allows the reefer trailer to be good for 7 years, although there is a more expensive model that I think has a DPF and can be used forever in their state as long as the DPF is maintained properly. But in your case you’re asking about an APU and you should be fine.
","text":"Ok tank you","replyToPid":431609}
发表于 2021-6-25 23:06:52 来自手机 | 显示全部楼层
{"replyToPid":431558,"replyTo":"
1269260 发表于 2021-06-25 11:36:50 Ok good because canada try make everything green emissions they will make a law the reefer under 20—- willbe the same for the truck under 2000
","text":"In CA the law generally allows new reefer trailers to be good for 7 years, although there is a more expensive model that I think has a DPF and can be used forever in their state as long as the DPF is maintained properly. But in your case you’re asking about an APU and you should be fine. "}
发表于 2021-6-25 10:50:48 来自手机 | 显示全部楼层
","text":"CA DOT officers are not in charge of checking emissions and could care less as its not their job. CARB sends people to weigh station to check. ","replyToPid":431469}
禁止发言
发表于 2021-6-25 10:03:50 来自手机 | 显示全部楼层
 楼主| 发表于 2021-6-25 09:32:58 来自手机 | 显示全部楼层
1269260 发表于 2021-06-25 01:25:20 No they will try out no law yet
","text":"They will try the male one if past well  rhey will try the past the law if working good","replyToPid":431493}
 楼主| 发表于 2021-6-25 08:19:15 来自手机 | 显示全部楼层
1269260 发表于 2021-06-25 00:17:58 Got thermo king evolution
","text":"Dont have dpf on it","replyToPid":431471}
发表于 2021-6-25 08:14:12 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"I have never heard a CA DOT officer check if the APU complies with their regulations. I think the TK Tripac Evolution APU does come with some sort of DPF, while the regular Tripac does not. I personally wouldn’t lose any sleep over using old model APUs."}
禁止发言
发表于 2021-6-25 08:21:22 来自手机 | 显示全部楼层
发表于 2021-6-25 08:23:02 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"The main concerns in CA apply to the truck engine and the trailer reefer. Those need to be registered. I’m not exactly sure about the APU, but I never had my old Tripac APU registered."}
 楼主| 发表于 2021-6-25 08:27:28 来自手机 | 显示全部楼层
147103 发表于 2021-06-25 00:21:22 I have tripac evolution. It has no def on it.
","text":"On batterie on and off get nerve reck when truck start","replyToPid":431474}
 楼主| 发表于 2021-6-25 08:28:37 来自手机 | 显示全部楼层
1269260 发表于 2021-06-25 00:27:28 On batterie on and off get nerve reck when truck start
","text":"I nkow tp dont have d e f","replyToPid":431479}
发表于 2021-6-25 08:40:53 来自手机 | 显示全部楼层
{"replyToPid":431474,"replyTo":"
","text":"I’m actually referring to DPF, which is a filter. I did a quick search and it looks like it’s possible to order the Tripac Evolution without a DPF. The APUs with a DPF would not use DEF (the liquid) to my knowledge. They would work like the modern trailer reefers that have a DPF (to comply with CA regulations), but they do not require DEF. "}
GMT+8, 2026-4-17 16:51 , Processed in 0.081129 second(s), 24 queries .
