查看: 134|回复: 10
were do you wash your pots and pans
 楼主| 发表于 2021-6-25 07:49:16 来自手机 | 显示全部楼层 |阅读模式
{"text":"what is the best place for that ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-6-25 08:03:28 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"If I had any I would wash them in the shower sink. You can also carry a 3 gallon water bottle in your truck that you can fill at some fuel pumps and rest areas. To make cleaning your pans easier, don’t take longer than a few hours to clean them."}
发表于 2021-6-25 12:04:28 来自手机 | 显示全部楼层
1071983 发表于 2021-06-25 01:32:26 I’ve seen a guy washing pots/pans/plates & silverware in the men’s restroom at the TA west of Denver before.. 😆 freaking gross dude
","text":"I think you’re right. It might be best to just buy clean purified water to wash your dishes because you can’t trust these truck stops or rest areas to give you clean water. ","replyToPid":431494}
发表于 2021-6-25 08:34:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"They didn’t ask if you had any. They asked were to wash them. ","replyToPid":431460}
发表于 2021-6-25 08:25:59 来自手机 | 显示全部楼层
1088913 发表于 2021-06-25 00:23:09 Non stick pots and pans are the best because you can get a wet paper towel and they wipe clean. It’s what we do
","text":"That’s actually what I used to do to clean my pans quickly (back when I cooked in my truck), but there’s nothing like pouring running water over your pans.","replyToPid":431477}
发表于 2021-6-25 07:52:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"Don’t have any ","replyToPid":0}
发表于 2021-6-25 08:02:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"Blue bacon may by is i tink what it is","replyToPid":431460}
发表于 2021-6-25 08:23:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"Non stick pots and pans are the best because you can get a wet paper towel and they wipe clean. It’s what we do","replyToPid":0}
发表于 2021-6-25 08:21:39 来自手机 | 显示全部楼层
279311 发表于 2021-06-25 00:03:28 If I had any I would wash them in the shower sink. You can also carry a 3 gallon water bottle in your truck that you can fill at some fuel pumps and rest areas. To make cleaning your pans easier, don’t take longer than a few hours to clean them.
","text":"Good one","replyToPid":431466}
发表于 2021-6-25 08:34:19 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"I carry a portable shower that I use for dishes also. But get a hotlogic mini. Use foil....life changing "}
发表于 2021-6-25 09:05:40 来自手机 | 显示全部楼层
1248278 发表于 2021-06-25 00:34:11 They didn’t ask if you had any. They asked were to wash them.
","text":"🤔🤔","replyToPid":431481}
GMT+8, 2026-2-9 22:40 , Processed in 0.065877 second(s), 24 queries .
