查看: 307|回复: 11
When to use sleeper berth
 楼主| 发表于 2021-6-22 21:13:37 来自手机 | 显示全部楼层 |阅读模式
{"text":"Should I take my first break early when I have more drive time or later when I’m almost out of time. Which gives me more time back after my second break. ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-6-22 22:34:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"There’s no real answer to your vague question. Every scenario would be different. Only thing that really matters is how far away from your delivery you are. I would want to get there with the least amount of breaks possible.","replyToPid":0}
发表于 2021-6-22 21:24:51 来自手机 | 显示全部楼层
{"replyTo":"","text":"if you take 30 min break to early  it only starts 8 hrs over & have to take 2nd 30 min break.      myself.    I run 5 to 7 hrs do 30 min break  then finish out the day","replyToPid":0}
发表于 2021-6-24 09:06:57 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"The 7-hr or 8-hr sleeper split is generally used for multi-stop loads where really there’s no other way to make the deliveries. For most loads out there, you don’t need to use it. This rule has gotten more confusing with the latest change, so give your driver manager (DM) a call whenever you think you might need it, so that you use it correctly. There are also several videos on YouTube explaining the latest 7-8 hr sleeper split.\n\nAlso, taking a 10-hr break is the most efficient use of your elogs versus the 7-8 hr sleeper split. So don’t use it because you’ll get more driving hours in the long run because you will not. "}
发表于 2021-6-22 21:33:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"Wow that is good ","replyToPid":0}
 楼主| 发表于 2021-6-22 21:25:46 来自手机 | 显示全部楼层
687043 发表于 2021-06-22 13:24:51 if you take 30 min break to early  it only starts 8 hrs over & have to take 2nd 30 min break.      myself.    I run 5 to 7 hrs do 30 min break  then finish out the day
","text":"Ok. Thanks. That makes sense. ","replyToPid":430526}
 楼主| 发表于 2021-6-22 21:27:18 来自手机 | 显示全部楼层
","text":"What about my first sleeper berth break. I should have been more specific. Sorry ","replyToPid":430526}
发表于 2021-6-22 21:42:24 来自手机 | 显示全部楼层
1100502 发表于 2021-06-22 13:27:18 What about my first sleeper berth break. I should have been more specific. Sorry
","text":"1st break. ??      after you start your clock. only have 30 min break then 10 hr break. that has to be done.","replyToPid":430530}
发表于 2021-6-22 21:43:25 来自手机 | 显示全部楼层
{"replyTo":"","text":"what's good.","replyToPid":430532}
 楼主| 发表于 2021-6-22 21:46:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"I’m not talking about the mandatory 30 min break. I’m talking about the best way to use split sleeper berth. Thanks though. ","replyToPid":0}
发表于 2021-6-22 21:49:19 来自手机 | 显示全部楼层
1100502 发表于 2021-06-22 13:46:13 I’m not talking about the mandatory 30 min break. I’m talking about the best way to use split sleeper berth. Thanks though.
","text":"oh hell.  on that I have no clue.","replyToPid":430544}
 楼主| 发表于 2021-6-22 21:55:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"Me either!","replyToPid":0}
GMT+8, 2026-4-17 17:07 , Processed in 0.140146 second(s), 24 queries .
