查看: 260|回复: 16
Ice 🧊 😂
 楼主| 发表于 2021-6-19 04:28:04 来自手机 | 显示全部楼层 |阅读模式
{"text":"Okay I have to ask… who has the best ice. I’m one of those weirdos that can’t help but chomp down on ice. #helllp ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
 楼主| 发表于 2021-6-19 06:33:47 来自手机 | 显示全部楼层
{"replyToPid":429529,"replyTo":"
1157302 发表于 2021-06-18 20:47:38 This comment has been deleted
","text":"Ummm 🤔 clearly someone is pretending to be me lol 😂 I’ll happily give my Snapchat "}
回复 支持 4 反对 3
发表于 2021-6-29 08:17:16 来自手机 | 显示全部楼层
{"replyTo":"","text":"Good God you're a piggy I can barely see your wrist.","replyToPid":0}
回复 支持 2 反对 4
 楼主| 发表于 2021-6-20 00:06:24 来自手机 | 显示全部楼层
655805 发表于 2021-06-19 10:35:45 Be careful how you use that term “ice” - there may be some people who enjoy a piece of “ice” now and then
","text":"I think of drugs but actually mean ice ","replyToPid":429628}
回复 支持 4 反对 2
发表于 2021-6-29 08:18:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"🐷🐽🐽🐽🐽🐽🐗","replyToPid":0}
回复 支持 1 反对 4
 楼主| 发表于 2021-6-29 04:19:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"I thought I was the only one that thought that!! ","replyToPid":432383}
 楼主| 发表于 2021-6-29 18:18:44 来自手机 | 显示全部楼层
279311 发表于 2021-06-28 23:39:49 What’s the ice for? Your ice chest? You’re better off with an electric cooler. They only go 40 degrees below room temperature, but you won’t have to worry about ice. If you have an outlet, you can get yourself the smallest fridge at Walmart. Your batteries will be fine as long as there are 4 batteries and you don’t leave it connected with your engine off for more than 24 hrs. You can idle your engine for 1.5 hrs to make it last another 24 hrs.
","text":"To eat lmfao. I’m an ice eater. Sorry 😂","replyToPid":432442}
发表于 2021-6-29 07:39:49 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"What’s the ice for? Your ice chest? You’re better off with an electric cooler. They only go 40 degrees below room temperature, but you won’t have to worry about ice. If you have an outlet, you can get yourself the smallest fridge at Walmart. Your batteries will be fine as long as there are 4 batteries and you don’t leave it connected with your engine off for more than 24 hrs. You can idle your engine for 1.5 hrs to make it last another 24 hrs. "}
发表于 2021-6-19 18:35:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"Be careful how you use that term “ice” - there may be some people who enjoy a piece of “ice” now and then ","replyToPid":0}
 楼主| 发表于 2021-6-29 18:19:04 来自手机 | 显示全部楼层
673231 发表于 2021-06-29 00:26:59 Crushed ice from flying j is the best
","text":"I do like flying j too ","replyToPid":432456}
 楼主| 发表于 2021-6-29 18:19:21 来自手机 | 显示全部楼层
1272718 发表于 2021-06-29 00:18:35 🐷🐽🐽🐽🐽🐽🐗
","text":"🐽 you right because I snack on ice way too much 💕","replyToPid":432450}
回复 支持 0 反对 3
发表于 2021-6-19 11:25:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"Circle K or Speedway ","replyToPid":0}
发表于 2021-6-23 18:06:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"Add me on Snapchat! Username: osxar_garci2021 https://www.snapchat.com/add/osxar_garci2021","replyToPid":0}
发表于 2021-6-23 18:06:34 来自手机 | 显示全部楼层
1240889 发表于 2021-06-23 10:06:10 Add me on Snapchat! Username: osxar_garci2021 https://www.snapchat.com/add/osxar_garci2021
","text":"Good Morning 🙏","replyToPid":430826}
发表于 2021-6-29 04:10:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"best ice is Throton's","replyToPid":0}
GMT+8, 2026-2-9 22:40 , Processed in 0.113589 second(s), 24 queries .
