查看: 169|回复: 4
Different size fuel tanks okay?
 楼主| 发表于 2021-6-19 01:53:15 来自手机 | 显示全部楼层 |阅读模式
{"text":"So the truck I’ll be buying has two 80 gallon tanks. I want to have a total of at least 200 gallons. Is it okay to have one 120 gal fuel tank and the other 80 gal?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-6-19 02:20:58 来自手机 | 显示全部楼层
{"replyTo":"","text":"I bought a truck setup similar to that years ago. was no issue.  they equal out the same","replyToPid":0}
发表于 2021-6-19 02:05:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"It isn't an issue. there are a lot of trucks on the road with different size tanks.","replyToPid":0}
发表于 2021-6-19 07:11:19 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yup perfectly fine, mine has a 110 and a 70 from the factory ","replyToPid":0}
发表于 2021-6-19 03:03:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"I run with 3 150 gallon tanks you just have to watch you axle weight","replyToPid":0}
GMT+8, 2026-4-17 16:50 , Processed in 0.101726 second(s), 24 queries .
