查看: 144|回复: 10
Tri Pack
 楼主| 发表于 2021-6-17 23:42:53 来自手机 | 显示全部楼层 |阅读模式
{"text":"What’s up everyone.Hope you guys safe on the road. \nI have 2021 Volvo VNL 860 and I’m planning to purchase Tri Pack any suggestions? Where should I buy? \nThanks in advance \nBe safe","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-6-18 10:53:43 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"They should throw in a pair of addidas sandals for you to match that chineesse truck bro 👍"}
发表于 2021-6-17 23:49:01 来自手机 | 显示全部楼层
{"replyTo":"","text":"Awesome! Congrats on your new truck! ","replyToPid":0}
 楼主| 发表于 2021-6-18 10:47:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"Thanks a lot ","replyToPid":0}
发表于 2021-6-18 05:23:14 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"To my knowledge, the Thermo King APU is the most common diesel APU out there. The Carrier brand should still be okay, but because the TK APU is more popular, you’ll find more repair/maintenance videos on YouTube than on the Carrier brand. Also, the inverter isn’t exactly part of the TK brand. You can tell them to put one that’s got 3000 watts if you wanted one.\n\nFrankly, it’s kind of pointless to put a 5,000 or even 3,000 watt inverter when the APU cannot supply that kind of power for a minute. The 1800 watt inverter will easily run a 600 watt microwave, an electric kettle, and a fridge, although not all at the same time. Again, the 5,000 watts may allow you to run all of these at the same time, but it’ll be for under a minute because the APU cannot supply that much power continuously. Having the truck engine idling will do better than the APU, but it also has its limits.\n\nWhatever inverter you end up going with, try to get a “pure sine” inverter. They’re supposed to be better, I’ve been told."}
发表于 2021-6-18 01:35:16 来自手机 | 显示全部楼层
{"replyTo":"","text":"Go with a Carrier, it has an actual generator. I think it’s 5,000 watts. Where the Tri Pack comes with a very limiting 1800 watt power inverter. ","replyToPid":0}
 楼主| 发表于 2021-6-18 03:47:16 来自手机 | 显示全部楼层
936953 发表于 2021-06-17 17:35:16 Go with a Carrier, it has an actual generator. I think it’s 5,000 watts. Where the Tri Pack comes with a very limiting 1800 watt power inverter.
","text":"Thanks a lot","replyToPid":429202}
发表于 2021-6-18 13:20:06 来自手机 | 显示全部楼层
{"replyTo":"","text":"ok if you're going to use a tripack please make sure you service it regularly, I don't have anything against those but if not properly maintained they put out extremely dangerous carbon monoxide fumes, I've been hospitalized twice because drivers failed to take care of them, I've even had my windows closed up tight and done no good","replyToPid":0}
 楼主| 发表于 2021-6-18 13:48:48 来自手机 | 显示全部楼层
1248444 发表于 2021-06-18 05:20:06 ok if you're going to use a tripack please make sure you service it regularly, I don't have anything against those but if not properly maintained they put out extremely dangerous carbon monoxide fumes, I've been hospitalized twice because drivers failed to take care of them, I've even had my windows closed up tight and done no good
","text":"Sure will do \nThank for the information ","replyToPid":429320}
 楼主| 发表于 2021-6-18 13:48:54 来自手机 | 显示全部楼层
1034056 发表于 2021-06-18 02:53:43 They should throw in a pair of addidas sandals for you to match that chineesse truck bro 👍
","text":"Haha","replyToPid":429286}
GMT+8, 2026-2-10 02:02 , Processed in 0.124620 second(s), 24 queries .
