查看: 108|回复: 10
New york to pa state line 81 souht all close
 楼主| 发表于 2021-6-16 23:05:22 来自手机 | 显示全部楼层 |阅读模式
发表于 2021-6-17 00:58:18 来自手机 | 显示全部楼层
{"replyTo":"","text":"Here’s your sign……","replyToPid":0}
发表于 2021-6-16 23:52:44 来自手机 | 显示全部楼层
{"replyTo":"","text":"Wow. Someone failed grade 1. Also grades 2-12. ","replyToPid":0}
1万
发表于 2021-6-16 23:45:30 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"oh, the scale is closed...\nreally ??? \nI think that's what the app is for...\n😖😩🤪"}
1万
发表于 2021-6-16 23:24:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"what is souht ???\ndo you mean shut down, \nall closed ???","replyToPid":0}
 楼主| 发表于 2021-6-16 23:28:56 来自手机 | 显示全部楼层
1031233 发表于 2021-06-16 15:24:42 what is souht ???\ndo you mean shut down, \nall closed ???
","text":"Scale sorry","replyToPid":428946}
 楼主| 发表于 2021-6-16 23:29:16 来自手机 | 显示全部楼层
{"replyTo":"","text":"Close","replyToPid":428947}
 楼主| 发表于 2021-6-16 23:30:29 来自手机 | 显示全部楼层
{"replyTo":"","text":"Scale close ","replyToPid":428949}
 楼主| 发表于 2021-6-16 23:57:02 来自手机 | 显示全部楼层
1248278 发表于 2021-06-16 15:52:44 Wow. Someone failed grade 1. Also grades 2-12.
","text":"Just like you did same class","replyToPid":428962}
 楼主| 发表于 2021-6-17 00:05:42 来自手机 | 显示全部楼层
1262951 发表于 2021-06-16 15:57:02 Just like you did same class
","text":"The dummy reward go to this two","replyToPid":428963}
GMT+8, 2026-2-10 03:33 , Processed in 0.073893 second(s), 24 queries .
