查看: 185|回复: 7
Air tank
 楼主| 发表于 2021-6-13 23:10:23 来自手机 | 显示全部楼层 |阅读模式
{"text":"Good morning everyone does anyone know of a easy way to replace the cables on the air tank behind the cab of a 2014 freightliner Cascadia evolution","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-6-14 06:34:07 来自手机 | 显示全部楼层
{"replyTo":"","text":"Easiest way to replace is buy a new truck ","replyToPid":0}
发表于 2021-6-14 00:25:54 来自手机 | 显示全部楼层
{"replyTo":"","text":"That’s a 10 minute job","replyToPid":0}
发表于 2021-6-13 23:39:14 来自手机 | 显示全部楼层
{"replyTo":"","text":"You mean the airline hoses, the wires, or the plastic airlines?","replyToPid":0}
发表于 2021-6-13 23:49:13 来自手机 | 显示全部楼层
279311 发表于 2021-06-13 15:39:14 You mean the airline hoses, the wires, or the plastic airlines?
","text":"He said the cables ","replyToPid":428514}
 楼主| 发表于 2021-6-14 00:15:33 来自手机 | 显示全部楼层
","text":"The cable that goes around the air tank behind the cab with the dryer on it I got one on but I’m having a hard time trying to get the one on by the tank no room to work with. Thank You ","replyToPid":428514}
 楼主| 发表于 2021-6-14 01:08:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"You didn’t say how I could get the one in by the tank. I thought was going to be a ten minute job but not so. Thank You ","replyToPid":428520}
发表于 2021-6-14 01:45:10 来自手机 | 显示全部楼层
{"replyToPid":428517,"replyTo":"
644760 发表于 2021-06-13 16:15:33 The cable that goes around the air tank behind the cab with the dryer on it I got one on but I’m having a hard time trying to get the one on by the tank no room to work with. Thank You
","text":"A picture would be helpful to understand your problem. If you mean that you don’t fit under the truck, then try driving over some wood blocks with your drive tires so you have a few more inches of room. You can also remove the center catwalk behind the cab. Some are easily removable and do not require any tools.\n\nOr is the problem that you cannot fit your tools to remove the air tank bracket? If you’re replacing the bracket (which comes with a cable), then try snapping off the cable with a wire cutter plier or angle grinder."}
GMT+8, 2026-4-15 17:41 , Processed in 0.090501 second(s), 24 queries .
