查看: 190|回复: 9
Answer me this... if anyone can
 楼主| 发表于 2021-6-12 05:18:17 来自手机 | 显示全部楼层 |阅读模式
{"text":"why is it Boise scale in Idaho whether you're eastbound or westbound always pull the belt trailers in... when I have a reefer trailer on loaded or empty I get the green light but with the Bell trailer loaded or empty I'm getting the red light and have to go through the scale.. why is that","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-6-27 22:46:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"💕💕","replyToPid":0}
 楼主| 发表于 2021-6-12 11:17:21 来自手机 | 显示全部楼层
842984 发表于 2021-06-12 01:32:01 they just wanna check out that cool load u runnin, they don't wanna look at anymore box vans lol
","text":"so when I'm empty they're checking out the air in the trailer... I wouldn't doubt it for a minute if they work","replyToPid":428375}
发表于 2021-6-12 05:53:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"How many axles on both trailers?","replyToPid":0}
发表于 2021-6-12 09:32:01 来自手机 | 显示全部楼层
{"replyTo":"","text":"they just wanna check out that cool load u runnin, they don't wanna look at anymore box vans lol","replyToPid":0}
 楼主| 发表于 2021-6-12 11:09:52 来自手机 | 显示全部楼层
279311 发表于 2021-06-11 21:53:37 How many axles on both trailers?
","text":"reefer trailers the tandem my belt trailers for axles ones that drop","replyToPid":428352}
发表于 2021-6-12 11:43:04 来自手机 | 显示全部楼层
208374 发表于 2021-06-12 03:09:52 reefer trailers the tandem my belt trailers for axles ones that drop
","text":"That could be it. Trailers with more than two axles will probably always pull you in if the weigh station has the weigh-in-motion scales on the freeway. ","replyToPid":428379}
发表于 2021-6-13 08:40:09 来自手机 | 显示全部楼层
208374 发表于 2021-06-12 03:17:21 so when I'm empty they're checking out the air in the trailer... I wouldn't doubt it for a minute if they work
","text":"Gotta make sure your sailboat fuel is placard right ⛵️","replyToPid":428381}
 楼主| 发表于 2021-6-13 16:18:50 来自手机 | 显示全部楼层
1241785 发表于 2021-06-13 00:40:09 Gotta make sure your sailboat fuel is placard right ⛵️
","text":"Lol...","replyToPid":428452}
发表于 2021-7-23 20:03:22 来自手机 | 显示全部楼层
{"replyTo":"","text":"Hello how are you doing ? ","replyToPid":0}
GMT+8, 2026-2-9 09:29 , Processed in 0.061636 second(s), 24 queries .
