查看: 885|回复: 33
DD15 Engine replacement or another truck!?
 楼主| 发表于 2021-6-10 10:04:23 来自手机 | 显示全部楼层 |阅读模式
{"text":"So the dealer told me my truck (975k miles) will need a new engine. The engine cannot be rebuilt. The cost for a “complete” new engine replacement with components like the fuel pump, air compressor, etc. and labor will be roughly 53k. I can also get a so called 3/4 new engine replacement that won’t come with the fuel pump, etc. I haven’t gotten a quote for the 3/4 engine, but I think it’s possibly about 40k.\n\nRight now I am leaning more toward buying another truck, preferably a new truck, except that there are practically no new trucks available nationwide from Freightliner, Kenworth, or Peterbilt. They’re backed up by months due to the coronavirus and a shortage of microchips that these trucks use. So maybe I’ll just try to get the newest used truck possible because the used truck sales are off the charts due to a serious shortage of new trucks.\n\nPete!!! What do you think?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-6-11 09:25:15 来自手机 | 显示全部楼层
{"replyToPid":428247,"replyTo":"
279311 发表于 2021-06-10 21:09:48 Well, I’m back. I woke up to nausea and a headache. Eventually vomit, then back to sleep! I was thinking covid, but maybe it was the stress/anxiety of the past couple of days.
","text":"Yea your fault professor for keeping a junk truck until 975k needing a new engine.  The world is just full of educated fools."}
回复 支持 4 反对 1
发表于 2021-6-11 04:36:26 来自手机 | 显示全部楼层
766797 发表于 2021-06-10 03:16:42 you are correct ...understand I do NOT miss going on there...thank you for your time and response
","text":"I was hoping California would break off and float away, and take the weirdos with it. No offense to anyone who lives there and is normal. There has to be at least one person……. Maybe?😳","replyToPid":428173}
发表于 2021-6-11 12:10:28 来自手机 | 显示全部楼层
{"replyTo":"","text":"Guess I’m just old and grumpy. The only reason it’s illegal is because there is money in selling you a new one. It’s not for saving the planet. Same reason we have an eld, money, job creation, not safety. See them every day,racing the clock , both feet flat on the floor. Maybe I’m not old , just bitter I guess. I also run more than one truck, and after 38 years,seen my share of change,not all of it good. Tired of getting rear ended by more rules !","replyToPid":0}
发表于 2021-6-22 12:59:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"Gliders are not worth the 140k to avoid DEF. A glider is an over priced rebuilt truck with 1 year warranty.? If you are into trucking you have to understand the def system and most of the repairs can be done by you. ","replyToPid":0}
发表于 2021-6-11 00:35:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"Just an FYI swapping an older 60 series in will be eld exempt and they break down half as often as new engines. Our best fleet truck is a 386 with a 60 series. It takes oil changes and brakes. Most reliable we have. And we have cats, cummins, Detroit’s and Volvos. ","replyToPid":0}
禁止发言
发表于 2021-6-10 10:31:08 来自手机 | 显示全部楼层
 楼主| 发表于 2021-7-1 07:32:07 来自手机 | 显示全部楼层
{"replyTo":"","text":"Come out and show yourself. Stop hiding in fake accounts. 🐓 ","replyToPid":433108}
发表于 2021-6-30 23:47:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"Have you checked the truck paper? They usually have companies that sell engines in there. I’ve seen them at the back of the booklet. Grab one at the truck stop. ","replyToPid":0}
发表于 2021-6-13 05:51:44 来自手机 | 显示全部楼层
1258332 发表于 2021-06-10 03:12:15 I think your at the wrong shop. A friend of mine just went through the same thing, only with a Cummins. He bought a running junk yard N-14, and had his shop go through it and install it in his truck, and didn’t have 10k in the whole thing. The shop used Cummins parts by the way. Don’t know where you live , he lives in GA. Can’t see where the geographic location could change the price too much.
","text":"I won’t have a rig that is not under warranty. \nI would suggest a new Western Star with a X15 or a DD16. You can have them worked on anywhere. ","replyToPid":428169}
 楼主| 发表于 2021-6-11 05:09:48 来自手机 | 显示全部楼层
{"replyTo":"","text":"Well, I’m back. I woke up to nausea and a headache. Eventually vomit, then back to sleep! I was thinking covid, but maybe it was the stress/anxiety of the past couple of days.","replyToPid":0}
发表于 2021-6-10 10:27:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"you can keep some of the old components and other parts off of the old motor. is the truck you have now is it paid off? you buy new your payment will be alot more than that new motor will be?","replyToPid":0}
 楼主| 发表于 2021-6-10 10:46:55 来自手机 | 显示全部楼层
{"replyToPid":428155,"replyTo":"
289718 发表于 2021-06-10 02:27:13 you can keep some of the old components and other parts off of the old motor. is the truck you have now is it paid off? you buy new your payment will be alot more than that new motor will be?
","text":"If I junk the truck, I’ll try to see what I can keep like the tires. Yeah, my truck is paid off.\n\nYes, the newer truck will cost more than the new engine, but the other problem I forgot to mention is that there is a delay in the availability of the engine. There are none available at the moment. I called a few Freightliners/Detroit dealers and they said it can be a wait time of up to 3 weeks to get it built and delivered. Then there’s another wait time to get it put together, which is probably 1.5 weeks. Sure, I can get a rental truck in the meantime, but it’ll be an extra expense. "}
 楼主| 发表于 2021-6-10 10:48:11 来自手机 | 显示全部楼层
1071983 发表于 2021-06-10 02:40:53 If you want a Peterbilt they have some new ones sitting in Altoona, IA lately. I know they have 389s on hand for sure.
","text":"I’ll give them a call.","replyToPid":428159}
 楼主| 发表于 2021-6-10 11:02:52 来自手机 | 显示全部楼层
{"replyToPid":428164,"replyTo":"
766797 发表于 2021-06-10 02:54:41 you know my answer my friend  for the money of new tuck I prefer buy 10k truck custom rebuild with 6nz or n14 out of frame ,sandblasted custom paint and interior,  rebuild all driveline ,wires,airlines you will end up with better like new and sure ride 1.5 million miles not yours 974k so you spend 125k$ and make 2times more money on miles and still have about 45,000 to buy a trailer..... just my way of thinking..🦕🦕🦕🇺🇸
","text":"If I had experience on those older engines I might give them a try, but I want to stick with a Freightliner Cascadia because that’s where all my mechanical experience is at."}
发表于 2021-6-10 11:12:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"I think your at the wrong shop. A friend of mine just went through the same thing, only with a Cummins. He bought a running junk yard N-14, and had his shop go through it and install it in his truck, and didn’t have 10k in the whole thing. The shop used Cummins parts by the way. Don’t know where you live , he lives in GA. Can’t see where the geographic location could change the price too much.","replyToPid":0}
 楼主| 发表于 2021-6-10 11:13:52 来自手机 | 显示全部楼层
766797 发表于 2021-06-10 03:07:04 Understand many Cascadia Gilders with D 60....
","text":"The other thing is that a glider wouldn’t be able to enter CA legally, right? I haven’t entered CA in a long time, but it’s a possibility for me because I do long haul. ","replyToPid":428167}
 楼主| 发表于 2021-6-10 11:15:28 来自手机 | 显示全部楼层
{"replyToPid":428169,"replyTo":"
","text":"I’m stuck in Rapid City, SD. It’s kinda limited over here, but the dealer looks legit. It’s a small city, but it’s very busy right now because of the seasonal tourism."}
 楼主| 发表于 2021-6-10 11:19:30 来自手机 | 显示全部楼层
{"replyToPid":428173,"replyTo":"
","text":"I hate going to CA because of the traffic. It’s always super busy over there. I like it better in OR and WA. Less nonsense and the round trip long distance freight pays about the same as in CA, although during the winter it can get complicated. "}
GMT+8, 2026-4-17 22:25 , Processed in 0.166450 second(s), 24 queries .
