查看: 211|回复: 8
Reefer trailer
 楼主| 发表于 2021-5-29 14:18:03 来自手机 | 显示全部楼层 |阅读模式
{"text":"Hauling produce setpoint is 34° display unit says 37° is a 3° fluctuation an issue?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-5-29 15:37:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"How many times are you going to ask this same question?","replyToPid":0}
回复 支持 3 反对 3
 楼主| 发表于 2021-5-29 21:57:31 来自手机 | 显示全部楼层
936953 发表于 2021-05-29 07:37:15 How many times are you going to ask this same question?
","text":"One or two more times","replyToPid":427370}
发表于 2021-5-30 07:17:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"Sometimes produce is warm when loaded. Takes the reefer a while to bring box temp to set point.","replyToPid":0}
发表于 2021-5-29 19:35:39 来自手机 | 显示全部楼层
{"replyTo":"","text":"No, just make sure you set produce loads to continuous. ","replyToPid":0}
发表于 2021-5-31 12:10:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"Take it to the dealer who made the unit and tell them to fix it. ","replyToPid":0}
发表于 2021-5-29 15:00:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"No most refers will fluctuate between 10 and 15°  shippers factor this and have you set it either Run stop or continuous I wouldn’t worry about it unless it gets 20° difference whether has a lot to do with this fluctuation","replyToPid":0}
1万
发表于 2021-5-29 18:13:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"Celsius or Fahrenheit ???","replyToPid":0}
发表于 2021-5-30 09:49:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"you are all good brother","replyToPid":427382}
GMT+8, 2026-2-7 22:56 , Processed in 0.059604 second(s), 24 queries .
