查看: 218|回复: 10
I think
 楼主| 发表于 2021-5-28 02:47:43 来自手机 | 显示全部楼层 |阅读模式
{"text":"I think TP should require our dot # to join that way all the trolls would be at least less ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-5-28 17:54:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"if they required a 4th grade education or higher entry test, that might eliminate 90% of the trash here.","replyToPid":0}
回复 支持 1 反对 8
禁止发言
发表于 2021-5-28 03:57:16 来自手机 | 显示全部楼层
回复 支持 9 反对 0
 楼主| 发表于 2021-5-28 03:08:15 来自手机 | 显示全部楼层
1229119 发表于 2021-05-27 18:59:49 Nope. Phone maybe. Not DOT.
","text":"what ever it takes to cut down on the trolls","replyToPid":427169}
发表于 2021-5-29 01:42:09 来自手机 | 显示全部楼层
1249349 发表于 2021-05-28 09:54:37 if they required a 4th grade education or higher entry test, that might eliminate 90% of the trash here.
","text":"Your the reason a verify system is needed. Your main focus is violence.","replyToPid":427220}
发表于 2021-5-29 00:06:04 来自手机 | 显示全部楼层
","text":"That would eliminate You .....Inbread/Accusme","replyToPid":427220}
发表于 2021-5-28 23:22:54 来自手机 | 显示全部楼层
","text":"That would eliminate you!  We all know you can't read.....NO PARKING!🤣🤣🤣","replyToPid":427220}
发表于 2021-5-28 05:43:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"Dot number is public information, wouldn’t help anything ","replyToPid":0}
发表于 2021-5-28 02:59:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"Nope. Phone maybe. Not DOT.","replyToPid":0}
发表于 2021-7-22 23:38:18 来自手机
{"replyTo":"","text":"Any one around Northern Michigan wanna drop their load off in my mouth? I’ll keep it safe in my throat.(;","replyToPid":0}
支持 0 反对 1
发表于 2021-5-29 04:34:01 来自手机 | 显示全部楼层
","text":"🤣🤣🤣🤣 did you look in mirror. BOY!","replyToPid":427220}
 楼主| 发表于 2021-5-28 20:23:33 来自手机 | 显示全部楼层
","text":"👍","replyToPid":427220}
GMT+8, 2026-4-19 11:53 , Processed in 0.127137 second(s), 25 queries .
