查看: 75|回复: 1
Anyone near cheneyville, LA?
 楼主| 发表于 2021-5-26 15:02:18 来自手机 | 显示全部楼层 |阅读模式
{"text":"It’s close to Alexandria, LA. In need of a coolant on my 2015 freightliner cascadia dd15. If anyone knows a good mechanic close by I’m not sure where coolant is leaking from. It’s on the left side. Truck won’t start now because coolant levels are low. ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-5-26 16:29:05 来自手机 | 显示全部楼层
{"replyTo":"","text":"Unplug you sensor from the reservoir and you can drive it like 5-10 miles away without breaking your truck ","replyToPid":0}
GMT+8, 2026-2-7 22:56 , Processed in 0.053893 second(s), 23 queries .
