查看: 205|回复: 4
Hey how's it going everyone? need some help trying to pick a good app for loads can you guys help me out?
 楼主| 发表于 2021-5-17 18:11:08 来自手机 | 显示全部楼层 |阅读模式
发表于 2021-5-18 22:19:20 来自手机 | 显示全部楼层
{"replyTo":"","text":"DAT ","replyToPid":0}
发表于 2021-5-18 09:05:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"DAT and Truck Stop load boards are usually seen as the most legit. I haul reefer and I’ve only ever used DAT. I’m happy with the service, but I’ve heard that Truck Stop focuses more on reefer. I can’t confirm. Maybe some day I give it a shot. \n\nYour best bet is to stick with legit companies. Yes, you’ll probably pay a bit more, but you also want to do business with legit brokerage companies. What’s the point in saving $25 a month on a cheap load board if you end up eventually bumping into a brokerage company that won’t pay you for the load you hauled for them. DAT screens both trucking and brokerage companies to make sure they’re legit. Nobody wants to be working with crooks.\n\nOne last tip and very important tip, don’t go cheap on the subscription. They have various “levels.” Also, get yourself either Verizon or AT&T.","replyToPid":0}
发表于 2021-5-18 02:39:21 来自手机 | 显示全部楼层
{"replyTo":"","text":"I’ve heard that DAT load board was a good one,haven’t tried it myself tho","replyToPid":0}
发表于 2021-5-23 07:15:50 来自手机 | 显示全部楼层
{"replyTo":"","text":"ayup. noplace better to line up a quick ride.\nnon-fiction!","replyToPid":425996}
GMT+8, 2026-4-17 21:23 , Processed in 0.094370 second(s), 24 queries .
