查看: 321|回复: 4
Weight question
 楼主| 发表于 2021-5-17 11:51:17 来自手机 | 显示全部楼层 |阅读模式
{"text":"if you're hauling helium, do you weigh less than your empty weight?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-5-18 09:37:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"You can tell when they are full of helium cause they hang a bunch of concrete blocks under em.","replyToPid":0}
发表于 2021-5-17 16:58:50 来自手机 | 显示全部楼层
{"replyTo":"","text":"because  helium is lighter than air.","replyToPid":0}
发表于 2021-5-18 09:18:16 来自手机 | 显示全部楼层
{"replyTo":"","text":"if it's high pressure helium cylinders,  they gain a small amount of weight when full, and the cylinders are already heavy.","replyToPid":0}
发表于 2021-5-19 01:14:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"nahh what do you think! you should be pushing 80,000 empty!","replyToPid":0}
GMT+8, 2026-4-16 08:17 , Processed in 0.115365 second(s), 24 queries .
