查看: 156|回复: 6
Reefer trailer
 楼主| 发表于 2021-5-17 07:11:18 来自手机 | 显示全部楼层 |阅读模式
{"text":"Is a to 2° fluctuation a big deal","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-5-18 09:22:07 来自手机 | 显示全部楼层
{"replyTo":"","text":"The fluctuations are normal. The temps when in continuous mode can rise a bit high (8 degrees off) right after finishing an automatic defrost. It’s normal. The reefer will throw a code if the reefer cannot bring the temperature to where it needs to be.\n\nProduce always uses continuous due to product respiration and frozen loads are generally safe in start/stop, but at the end of the day, you want to follow what the bills say, especially if the load comes with a temp recorder. The receiver can reject the load if they don’t like what they see in the recorder, although it’s never happened to me nor have I heard it happen. \n\nPersonally if there is no recorder on a frozen load, I put it in start/stop at night only. If the bills say zero degrees or below, then a start/stop of -10 will work. You can also ask the shipper if the load requires continuous or start/stop (assuming the bills don’t specify), but sometimes they do not know.","replyToPid":0}
发表于 2021-5-17 07:14:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"No","replyToPid":0}
 楼主| 发表于 2021-5-17 07:39:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"It was Supposed to be set on 32 it was running warm so I set it on 31 when I got to my location it was 30 it’s milk","replyToPid":0}
发表于 2021-5-17 07:57:31 来自手机 | 显示全部楼层
{"replyTo":"","text":"no","replyToPid":0}
 楼主| 发表于 2021-5-17 08:00:26 来自手机 | 显示全部楼层
{"replyTo":"","text":"Thanks!!","replyToPid":425949}
发表于 2021-5-17 08:52:09 来自手机 | 显示全部楼层
1243075 发表于 2021-05-16 23:39:34 It was Supposed to be set on 32 it was running warm so I set it on 31 when I got to my location it was 30 it’s milk
","text":"32 is freezing point, milk should be 34-36... but whatever they want. Mode settings also matter, start/sop, continuous.","replyToPid":425945}
GMT+8, 2026-2-7 21:16 , Processed in 0.053019 second(s), 24 queries .
