查看: 373|回复: 15
Delivering nothing
 楼主| 发表于 2021-5-16 16:07:43 来自手机 | 显示全部楼层 |阅读模式
{"text":"Tell me what you think about this, my dispatcher wants me to bobtail from Buffalo, NY all the way to a town outside Boston, MA just to pickup a empty trailer and then take that trailer all the way to jersey city, and then wants me to drive all the way back to the same place in MA and pickup another empty. What is the point in this","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-5-16 19:49:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"If it pays who cares what the point is ?","replyToPid":0}
回复 支持 9 反对 0
发表于 2021-5-17 04:44:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"you've probably been fůćķing up a lot so they use people like you to do menial work, but necessary, for the good drivers to stay moving!","replyToPid":0}
回复 支持 4 反对 2
发表于 2021-5-16 23:06:58 来自手机 | 显示全部楼层
{"replyTo":"","text":"well they probably don't need the trailers where they are and need them relocated. if your getting paid to do it then whats the issue","replyToPid":0}
发表于 2021-5-17 02:06:57 来自手机 | 显示全部楼层
1024815 发表于 2021-05-16 17:49:25 hauling empty is the best, it's like free money. I haul flat deck super bs in Canada and we can carry upto 63500kg total weight including truck and trailer and when your that heavy it takes a while to do anything. hauling empty is easy peasy
","text":"we use freedom units here cōmmie","replyToPid":425890}
回复 支持 4 反对 1
发表于 2021-5-16 17:25:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"to keep you busy","replyToPid":0}
发表于 2021-5-17 08:08:56 来自手机 | 显示全部楼层
{"replyTo":"","text":"Monetary system is base ten. Units of measure are based on the imperial system wherever the English throne exercised its imperial influence. ","replyToPid":0}
发表于 2021-5-16 23:15:29 来自手机 | 显示全部楼层
{"replyTo":"","text":"Trailers are a hot commodity right now. Maintaining a trailer pool often requires moving things around. Supply and demand.","replyToPid":0}
发表于 2021-5-17 04:27:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"Why ask why, drink a bud dry and enjoy the easy money.  ","replyToPid":0}
发表于 2021-5-17 06:57:00 来自手机 | 显示全部楼层
1157302 发表于 2021-05-16 18:06:57 we use freedom units here cōmmie
","text":"Goes to show what you know. Our monetary system is based on the metric system. 1 dollar = 100 cents. Cent is a unit of metric measurement that means 1/100. Weights and measures have absolutely nothing with politics (being a communist) and we don’t use the freedom system, it’s called English measurement system. Educate yourself before you make such ignorant comments. \nResentfully\nAmerican born and raised, but not ignorant","replyToPid":425891}
发表于 2021-5-17 11:59:32 来自手机 | 显示全部楼层
{"replyTo":"","text":"it's a test. so far, you're not doing very well.","replyToPid":0}
发表于 2021-5-16 17:02:18 来自手机 | 显示全部楼层
{"replyTo":"","text":"Empty move","replyToPid":0}
发表于 2021-5-17 01:49:25 来自手机 | 显示全部楼层
{"replyTo":"","text":"hauling empty is the best, it's like free money. I haul flat deck super bs in Canada and we can carry upto 63500kg total weight including truck and trailer and when your that heavy it takes a while to do anything. hauling empty is easy peasy","replyToPid":0}
GMT+8, 2026-2-7 21:16 , Processed in 0.075989 second(s), 24 queries .
