查看: 490|回复: 19
Driver Courtesy
 楼主| 发表于 2021-5-16 07:29:04 来自手机 | 显示全部楼层 |阅读模式
{"text":"I've been driving trucks since 2005 and I own 5 trucks in my company , the one thing me and my other drivers   talk about is how these new drivers have no courtesy whether it's at the fuel pump or in the truck stops inside or even on the road. most of them don't flash their headlights to let you know it's ok to move on over or interupt the trailer lights to say thank if you let them move in front you ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-5-16 07:38:20 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"I agree.  But also I don't need you to flash your high beams at me, at night, to know when to switch lanes, I know when to switch lanes. But if you insist, tell your drivers the proper way is turning them off and on."}
回复 支持 17 反对 1
发表于 2021-5-16 08:32:15 来自手机 | 显示全部楼层
936953 发表于 2021-05-16 00:09:10 I’m not your daddy, it’s not my job to tell you when to change lanes.
","text":"I suppose you think it’s courteous to be abrasive on this mans post. No one said it was your job, but it used to be understood courtesy. ","replyToPid":425845}
回复 支持 11 反对 0
发表于 2021-5-16 13:29:57 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"i leave my high beams on, you're clear whenever to change in front of me. But if you leave 5 inches, im changing lanes, speeding past you, and doing the same thing to you, and then when you try and pass I'm speeding to match."}
回复 支持 2 反对 6
发表于 2021-5-16 08:09:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"I’m not your daddy, it’s not my job to tell you when to change lanes.","replyToPid":0}
回复 支持 2 反对 6
发表于 2021-5-17 08:03:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"i'm a new a new driver. i'm still learning. But i do my best to be professional, and be courteous to other drivers ","replyToPid":0}
回复 支持 7 反对 0
 楼主| 发表于 2021-5-16 07:39:43 来自手机 | 显示全部楼层
{"replyTo":"","text":"that is correct driver","replyToPid":0}
回复 支持 6 反对 1
发表于 2021-5-17 15:48:52 来自手机 | 显示全部楼层
{"replyTo":"","text":"they are all from Nigeria or some other odd country.","replyToPid":0}
发表于 2021-5-16 11:39:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"it has always been outnof respect for many years for drivers to flash your lights to say hey your safe to move over ,we all have blind spots no matter who you are and we all want to make it back home and truck drivers are supposed to have a pact to stick together and always look out for one another, the new drivers have no idea yet but they will learn these things ,if they don't well us that do know ,knows what can happen and it's not a good thing !!","replyToPid":0}
发表于 2021-5-17 12:14:22 来自手机 | 显示全部楼层
","text":"i hope all your mechanics believe it's not their hob to tell you problems they notice when you come in but just do the requested work and keep quiet.\n\nand all your lady friends get themselves off and figure it's not their job to make sure you have a good time. \n\nand all your restaurant people figure you'll decide if the food might be too old\n\nand everyone agead of you when you're carrying a case if water decides it ain't their job to hold the door for you\n\nand your barber doesn't tell you about the lice\n\nand your broker doesn't mention the juicy loads you didn't ask about \n\nand the next driver who figures it's your job to know that your trailer brakes are smoking hot\n\nand the shipper who doesn't tell you the pallets have termites\n\nand the cashier who doesn't stop you from leaving without all the change you're due\n\nand the neighbor who doesn't say anything to or about the burglar creeping around your stuff.\n\nor anyone who doesn't say that they maybe just gave you tuberculosis or an STD or cooties of the strangs variety\n\nway to be a good citizen. \n\nmost of all i hope I never become like you or have people like you near me","replyToPid":425845}
发表于 2021-5-18 15:37:32 来自手机 | 显示全部楼层
{"replyTo":"","text":"I used to let people in when it was clear until one day someone yelled on the CB that he didn’t need my help that he was driving for 20 years and a billion miles. Everyone man for themselves now","replyToPid":0}
发表于 2021-5-16 11:27:28 来自手机 | 显示全部楼层
{"replyTo":"","text":"Way I see it, they will learn or suffer the consequences eventually. Counter professional behavior adversely affects us all.","replyToPid":0}
发表于 2021-5-16 23:43:24 来自手机 | 显示全部楼层
1034056 发表于 2021-05-15 23:38:20 I agree.  But also I don't need you to flash your high beams at me, at night, to know when to switch lanes, I know when to switch lanes. But if you insist, tell your drivers the proper way is turning them off and on.
","text":"this is the poor attitude right here : \"nobody tells me when to change lanes\" grow the Fck up boy","replyToPid":425841}
回复 支持 0 反对 3
GMT+8, 2026-2-10 07:11 , Processed in 0.086016 second(s), 24 queries .
