查看: 240|回复: 4
Lost due to wrong routing. Can I get my subcriber amount back?
 楼主| 发表于 2021-5-15 01:09:42 来自手机 | 显示全部楼层 |阅读模式
发表于 2021-5-15 08:21:51 来自手机 | 显示全部楼层
{"replyTo":"","text":"Learn how to read a map","replyToPid":0}
发表于 2021-5-17 12:24:44 来自手机 | 显示全部楼层
{"replyTo":"","text":"please park the vo vo and uber yourself to another line of work. you're not good at this.\n\nthe motoring public will be grateful.","replyToPid":0}
发表于 2021-5-15 04:10:59 来自手机
{"replyTo":"","text":"You are an ídiot. There’s no refund for mental illness. ","replyToPid":0}
支持 1 反对 0
发表于 2021-5-18 09:29:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"Never trust any trucking GPS. They ALL have flaws, and they generally do a poor job at routing. The only one that I have used that was smarter than all of the ones I’ve used was from Navigo on the Omnitracs. Theirs is a bit of a merge between Google maps and a trucking routes, but every once in a while, the routing would stink.\n\nWhen on new roads, I use Google maps and a Rand McNally road atlas. Also the “Street maps” comes in handy if you need to look at a bridge height or for any truck restriction signs. Generally, wider streets will allow trucks, while smaller streets can have no truck signs or weight restrictions. ","replyToPid":0}
发表于 2021-6-21 08:45:58 来自手机 | 显示全部楼层
{"replyTo":"","text":"Nope!!! use at your own risk","replyToPid":0}
GMT+8, 2026-3-21 21:06 , Processed in 0.084615 second(s), 24 queries .
