查看: 291|回复: 9
what do you thing
 楼主| 发表于 2021-5-14 19:13:07 来自手机 | 显示全部楼层 |阅读模式
{"text":"picking up a load in Cadillac Michigan going to Minneapolis Minnesota looks like I could go through the U.P and maybe save some time by avoiding the mess on 80/94 and 294 any thoughts ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-5-14 20:40:48 来自手机 | 显示全部楼层
{"replyTo":"","text":"You won't save any time, but you will spare yourself Chicago.","replyToPid":0}
回复 支持 6 反对 0
发表于 2021-5-19 00:38:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"to avoid Chicago will actually save you time during the day with rush hour traffic all day and may to October you can or used to be able to put your semi on a ferry it used to be around 100 bucks on u.s. hwy 10 it was like $125 well worth it cross in a hr","replyToPid":0}
发表于 2021-5-14 20:46:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"25$ one way on bridge to the north","replyToPid":0}
发表于 2021-5-22 11:21:30 来自手机 | 显示全部楼层
766797 发表于 2021-05-22 00:33:57 respectfully disagree if I do run from north Michigan customer I go UP do this about 60 times a year in summer not going in there in winter  newer get escorted and when the chicken light show is  on its something to see in person  especially how locals and visitors show respect and appreciation for trucking industry 👏👍 love it🇺🇸
","text":"All good, I don't get 60 trips in a year. But I've run it enough to know the good nd the bad of it. Summer tourists or winter squalls nd it ain't much fun. Safe travels whatever way the travel takes you.","replyToPid":426412}
发表于 2021-5-19 00:39:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"the ferry's run from Ludington mi. to Manitowoc WI.","replyToPid":0}
 楼主| 发表于 2021-5-14 19:38:36 来自手机 | 显示全部楼层
766797 发表于 2021-05-14 11:32:02 that's what I do my friend..go for it instead IN  IL Chicago mess beautiful scenery and Mackinac Bridge ‼️‼️ You will love it make some pictures along the way....
","text":"thanks Pete was making sure I was thinking right","replyToPid":425691}
 楼主| 发表于 2021-5-14 19:37:24 来自手机 | 显示全部楼层
1071983 发表于 2021-05-14 11:15:14 Do it. Enjoy the scenery in the process. 🌲🌲🌲
","text":"thanks just wanted to se if I was thinking right besafe","replyToPid":425687}
发表于 2021-5-22 07:30:31 来自手机 | 显示全部楼层
766797 发表于 2021-05-14 13:11:33 Chicago =TIME‼️‼️‼️
","text":"US2 across UP=TIME! If it's windy and dot is escorting BRIDGE=TIME! I've ran both routes plenty, and if I'm looking to cover ground quick. I'll head it through Chicago!!!","replyToPid":425703}
发表于 2021-5-23 10:29:24 来自手机 | 显示全部楼层
1186524 发表于 2021-05-18 16:38:03 to avoid Chicago will actually save you time during the day with rush hour traffic all day and may to October you can or used to be able to put your semi on a ferry it used to be around 100 bucks on u.s. hwy 10 it was like $125 well worth it cross in a hr
","text":"BS on the cross in an hr. It takes the Badger around 4 hrs to make the trip across and you have to have a reservation for a big truck","replyToPid":426069}
GMT+8, 2026-4-20 04:19 , Processed in 0.076902 second(s), 24 queries .
