查看: 334|回复: 8
Trucker randomly turning on ignition while parked?
 楼主| 发表于 2021-5-14 09:02:19 来自手机 | 显示全部楼层 |阅读模式
{"text":"Every once in a while I’m outside inspecting my truck or working on my truck and the truck driver next to me turns on his ignition, but doesn’t turn on his engine. He does this a few times. What is going on?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-5-14 10:06:25 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Peterbilt have turn key to on position for windows "}
发表于 2021-5-15 04:10:04 来自手机
{"replyTo":"","text":"Shut your goddam mouth fággòt","replyToPid":0}
支持 2 反对 0
发表于 2021-5-14 09:12:43 来自手机 | 显示全部楼层
{"replyTo":"","text":"Maybe auto start. Opti idle starting and stopping truck","replyToPid":0}
发表于 2021-5-17 05:12:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"he's trying to pick you up.","replyToPid":0}
 楼主| 发表于 2021-5-14 09:34:39 来自手机 | 显示全部楼层
{"replyTo":"","text":"This seems like the answer, but I would think that turning the key to the accessories would also let you use your power windows. Maybe it doesn’t work in some trucks. ","replyToPid":425637}
发表于 2021-5-14 10:23:24 来自手机 | 显示全部楼层
{"replyTo":"","text":"he is watching you","replyToPid":0}
发表于 2021-5-14 10:01:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"Opti Idle was my first thought also, but they said the engine doesn't turn on.  🤷‍♀️","replyToPid":0}
发表于 2021-5-14 09:28:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"Power widows","replyToPid":0}
发表于 2021-5-17 09:50:47 来自手机 | 显示全部楼层
{"replyTo":"","text":"I have a KW.  I have to do that to roll my windows up/ down when the engine is OFF.  Now you know why he did it...😁","replyToPid":0}
GMT+8, 2026-4-20 05:55 , Processed in 0.106641 second(s), 24 queries .
