查看: 143|回复: 3
boost regulator in the cab?
 楼主| 发表于 2021-5-14 00:19:00 来自手机 | 显示全部楼层 |阅读模式
{"text":"wastegate is pinched off. I want to install a regulator so I can can block off wastegate when I want more power. or open it fully when running flat and light to keep fuel mileage up.\nI'm a jęw so I don't want to spend alot.\nthinking a paint sprayer regulator.  real cheap.","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-5-14 03:22:16 来自手机 | 显示全部楼层
{"replyTo":"","text":"Drill 2 quarter inch holes about a foot apart thru the firewall,run mechanics wire thru 1st hole,wrap it around waste gate valve a couple times,run the remaining wire back thru the second hole, there you have it,variable waste gate control !!! Should only cost a buck two ninety eight !!!!!","replyToPid":0}
发表于 2021-5-14 04:31:59 来自手机 | 显示全部楼层
1241685 发表于 2021-05-13 19:22:16 Drill 2 quarter inch holes about a foot apart thru the firewall,run mechanics wire thru 1st hole,wrap it around waste gate valve a couple times,run the remaining wire back thru the second hole, there you have it,variable waste gate control !!! Should only cost a buck two ninety eight !!!!!
","text":"This is hilarious! You can also do the same thing when you windshield wipers break","replyToPid":425591}
 楼主| 发表于 2021-5-14 10:25:02 来自手机 | 显示全部楼层
","text":"hahaha I love it","replyToPid":425591}
GMT+8, 2026-4-20 06:32 , Processed in 0.061756 second(s), 24 queries .
