查看: 244|回复: 9
If I run out of DEF can I just pour a Red Bull in there?
 楼主| 发表于 2021-5-12 01:26:38 来自手机 | 显示全部楼层 |阅读模式
发表于 2021-5-12 03:07:28 来自手机 | 显示全部楼层
{"replyTo":"","text":"Just plss in it.","replyToPid":0}
发表于 2021-5-13 12:13:05 来自手机 | 显示全部楼层
{"replyTo":"","text":"water will be better","replyToPid":0}
发表于 2021-5-12 09:18:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"don't waste delicious redbull on that","replyToPid":0}
发表于 2021-5-13 08:59:12 来自手机 | 显示全部楼层
{"replyTo":"","text":"buy the way,what's def??? LOL !!","replyToPid":0}
发表于 2021-5-13 09:16:40 来自手机 | 显示全部楼层
{"replyToPid":425532,"replyTo":"
1241685 发表于 2021-05-13 00:59:12 buy the way,what's def??? LOL !!
","text":"Almost exactly the same thing as 28% UAN except that it has a little more water in it and it costs more. 28% is $.33 per gallon vs. $2.69+ for DEF. \nAnd yes, to get to the next station, uri nating in the tank will work without any adverse effects. I’m pretty sure that the guy that came up with it is laughing with his million aire buddies at the shee ple who were ignorant enough to accept it without a fi ght. "}
发表于 2021-5-13 08:57:45 来自手机
{"replyTo":"","text":"pee in it !!!","replyToPid":0}
支持 1 反对 0
发表于 2021-5-12 06:07:00 来自手机 | 显示全部楼层
{"replyTo":"","text":"I know it’s a joke, but I think you’ll just get a check engine light before you even run out of DEF. I don’t think it will ever turn off the engine, but it will eventually derate the engine speed to 5 mph.","replyToPid":0}
 楼主| 发表于 2021-5-12 06:38:57 来自手机 | 显示全部楼层
279311 发表于 2021-05-11 22:07:00 I know it’s a joke, but I think you’ll just get a check engine light before you even run out of DEF. I don’t think it will ever turn off the engine, but it will eventually derate the engine speed to 5 mph.
","text":"That being said, I’m going to back off now. You’re just trying to be a helpful person, and I should not be piling on you for that. Best of luck out there, driver","replyToPid":425323}
发表于 2021-5-12 08:33:06 来自手机 | 显示全部楼层
{"replyTo":"","text":"no...but since DEF is 65% water, you can only add a small amount of water, say 8 Oz. to get you to the absolute closest place with DEF, boxed or otherwise.","replyToPid":0}
 楼主| 发表于 2021-5-12 09:06:36 来自手机 | 显示全部楼层
891914 发表于 2021-05-12 00:33:06 no...but since DEF is 65% water, you can only add a small amount of water, say 8 Oz. to get you to the absolute closest place with DEF, boxed or otherwise.
","text":"Jesus ","replyToPid":425346}
GMT+8, 2026-4-20 05:00 , Processed in 0.096147 second(s), 24 queries .
