查看: 191|回复: 7
I'm pulling my push broom and it's not sweeping? help me drivers!
 楼主| 发表于 2021-5-11 23:50:28 来自手机 | 显示全部楼层 |阅读模式
 楼主| 发表于 2021-5-12 01:18:43 来自手机 | 显示全部楼层
1071983 发表于 2021-05-11 17:16:10 Get a battery powered leaf blower 💨💨💨
","text":"how do I plug it in?","replyToPid":425297}
发表于 2021-5-12 00:10:48 来自手机 | 显示全部楼层
{"replyTo":"","text":"Put the handle of the broom in your rear and walk backwards. It will sweep just fine","replyToPid":0}
发表于 2021-5-11 23:53:18 来自手机 | 显示全部楼层
{"replyTo":"","text":"haha.","replyToPid":0}
1万
发表于 2021-5-12 01:23:04 来自手机 | 显示全部楼层
{"replyTo":"","text":"the same way Tom said to use the broom 😲😲😲","replyToPid":425299}
发表于 2021-5-12 05:18:08 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"I second the leaf blower. It’s the real deal. Just make sure the floor is dry. You can turn on the heat to max in the reefer (and leave the rear vent door open) so it dries while you head to the shipper. If you have time, leave both doors open and even point it toward the sun and/or wind and it will dry quickly.\n\nDon’t go cheap on the leaf blower or it won’t have enough power to do the job right. If you don’t have an inverter, you can either buy a small inverter or charge the battery while you take a shower.\n\nLast note: Generally the trailer floor will be wet or moist after hauling a frozen load. Most refrigerated loads leave the floor fairly dry, unless water is dripping from the product like some produce loads, say, broccoli."}
发表于 2021-5-13 07:48:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"U R looking in the wrong direction,and secondly,I hope you don't have a left handed broom !!","replyToPid":0}
发表于 2021-5-15 15:00:39 来自手机 | 显示全部楼层
{"replyTo":"","text":"brooms. BAH!! Just ooen your doors, hi reverse for 150 to 200 feet, slam on brakes. return to starting location and repeat until your floor is clean.\n\nor get a flatbed & use renewable, sustainable wind power.","replyToPid":0}
GMT+8, 2026-4-20 04:44 , Processed in 0.060344 second(s), 25 queries .
