查看: 191|回复: 2
bridge heights
 楼主| 发表于 2021-5-11 07:17:45 来自手机 | 显示全部楼层 |阅读模式
{"text":"does this include bridge heights?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-5-11 07:30:48 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"There is an icon on the map for “low clearance.” Swipe to the left to see the rest of the icons you can select. Then it will appear on the map.\n\nYou can also try the Rand McNally road atlas, but theirs will only include low clearances from highways and not streets. Some states will have documents or maps on their websites with the full list of low clearances. \n\nFor the most part, if you stay on an interstate highway, you should be fine, unless you’re in New York. "}
回复 支持 4 反对 3
发表于 2021-5-11 08:50:11 来自手机 | 显示全部楼层
766797 发表于 2021-05-11 00:12:41 if you have CDL THAT'S YOURS BREAD AND BUTTER  you should know it
","text":"your correct sir. But you gotta realize this is probably the swift troll","replyToPid":425172}
GMT+8, 2026-4-16 10:24 , Processed in 0.079518 second(s), 24 queries .
