查看: 145|回复: 3
Why am I not seeing the weight stations on my map
 楼主| 发表于 2021-5-9 23:31:12 来自手机 | 显示全部楼层 |阅读模式
发表于 2021-5-9 23:47:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"You have to add them ","replyToPid":0}
发表于 2021-5-9 23:48:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"Open the places tab","replyToPid":0}
发表于 2021-5-10 00:16:48 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"You have to select the “weigh station” icon and it will appear. If you’re not new to the app, then it could be a technical problem with the app. Check to see if there’s a new update on the app. "}
GMT+8, 2026-3-22 05:39 , Processed in 0.063864 second(s), 23 queries .
