查看: 139|回复: 7
Dashcams
 楼主| 发表于 2021-5-8 22:39:30 来自手机 | 显示全部楼层 |阅读模式
{"text":"I'm interested in adding a dashcam or maybe 2. Any preference and why.\n","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-5-8 23:46:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"This post sponsored by Rènrèn Surveys Inc.","replyToPid":0}
回复 支持 5 反对 1
发表于 2021-5-9 07:52:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"I turn mine around and record me jęrking it to watch later that night","replyToPid":0}
发表于 2021-5-9 01:12:26 来自手机 | 显示全部楼层
279311 发表于 2021-05-08 15:26:48 I’ve tried various “off brands” from Amazon that had a ton of reviews, but they developed technical issues. Nowadays you cannot trust the reviews online because manufacturers are known for giving out free products in return for a positive review.\n\nI’m now using a Garmin dash cam and to my surprise it’s the best dash cam I’ve ever had to date. The best feature is that you can use the Garmin app to connect via Bluetooth/WiFi and quickly view/delete the videos on your phone. So no more having to connect your dash cam to your laptop. Just recently I got a message from my dash cam that the memory card was reaching the end of its life. A couple days ago, the dash cam stopped recording because it says the memory card is no good. Other than that, no problems so far.
","text":"We have used the Garmin GPS with the built in dashcam. The most frequent problem, which is probably common anyway, is the memory cards fry in the heat from being on the dash in extreme temps. We just carry extras with us now.","replyToPid":424847}
发表于 2021-5-8 23:26:48 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"I’ve tried various “off brands” from Amazon that had a ton of reviews, but they developed technical issues. Nowadays you cannot trust the reviews online because manufacturers are known for giving out free products in return for a positive review.\n\nI’m now using a Garmin dash cam and to my surprise it’s the best dash cam I’ve ever had to date. The best feature is that you can use the Garmin app to connect via Bluetooth/WiFi and quickly view/delete the videos on your phone. So no more having to connect your dash cam to your laptop. Just recently I got a message from my dash cam that the memory card was reaching the end of its life. A couple days ago, the dash cam stopped recording because it says the memory card is no good. Other than that, no problems so far. "}
发表于 2021-5-9 00:51:26 来自手机 | 显示全部楼层
{"replyTo":"","text":"I’ve got Nexar.  The app is incredibly easy to use, the cameras are durable and you can save your entire trip (my longest is 820 miles) for as long as you want.  I save mine for 2 weeks before ditching them","replyToPid":0}
发表于 2021-5-9 01:24:20 来自手机 | 显示全部楼层
1230539 发表于 2021-05-08 15:46:42 This post sponsored by Rènrèn Surveys Inc.
","text":"Nope. I’m not being paid by anyone. I’m a real trucker. ","replyToPid":424850}
发表于 2021-5-9 01:33:37 来自手机 | 显示全部楼层
611247 发表于 2021-05-08 17:12:26 We have used the Garmin GPS with the built in dashcam. The most frequent problem, which is probably common anyway, is the memory cards fry in the heat from being on the dash in extreme temps. We just carry extras with us now.
","text":"Does your Garmin GPS say something about the memory card needing replacing? With my other dash cams, I remember that they would stop recording, but it never said why. I also inserted a new memory card, and usually they started working again, but eventually the dash cam itself would not work.\n\nI think you’re right in that the heat is taking a toll on the memory cards and the dash cams. My situation is probably worse because I always use a windshield sun cover and the cover absorbes a lot of heat. I gotta find a way to prevent that without having to remove the dash cam every day. (I drive a lot at night and sleep in the day).","replyToPid":424860}
GMT+8, 2026-2-5 03:49 , Processed in 0.061293 second(s), 24 queries .
