查看: 78|回复: 6
Failed leadership causes this issue!
 楼主| 发表于 2021-5-7 20:52:08 来自手机 | 显示全部楼层 |阅读模式
{"text":"abc13.com","videos":"[]","link":"{\"picture\":{\"description\":\"\",\"height\":200.0,\"name\":\"\",\"url\":\"https://cdn.abcotvs.net/abcotv/static/ktrk/logos/ktrk_logo_2x.png\",\"width\":880.0},\"title\":\"29 detained in possible smuggling case involving big rig in San Antonio - ABC13 Houston\",\"type\":\"GENERAL\",\"url\":\"https://abc13.com/san-antonio-29-detained-in-possible-smuggling-case-people-found-inside-big-rig-texas-human-cases/10591413/\",\"valid\":true}","pics":"[]","canComment":true,"externalShare":false}
 楼主| 发表于 2021-5-8 02:18:33 来自手机 | 显示全部楼层
1237168 发表于 2021-05-07 14:43:10 then we change the law, easy, stoopid.
","text":"Good luck with that!! You can run your gums all you want. Human trafficking is against the law. Even in the sewer of California. You all for it then load your Swift truck with illegals. Then I can laugh as I watch you on TV being lead to the place you belong!","replyToPid":424770}
发表于 2021-5-7 20:59:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"0 dead, I'd call this a victimless crime.","replyToPid":0}
发表于 2021-5-7 22:43:10 来自手机 | 显示全部楼层
{"replyToPid":424762,"replyTo":"
1234089 发表于 2021-05-07 13:11:36 This comment has been deleted
","text":"then we change the law, easy, stoopid."}
 楼主| 发表于 2021-5-7 21:11:12 来自手机 | 显示全部楼层
1237168 发表于 2021-05-07 12:59:13 0 dead, I'd call this a victimless crime.
","text":"Sure FORHISGLORY","replyToPid":424758}
 楼主| 发表于 2021-5-7 21:15:39 来自手机 | 显示全部楼层
","text":"https://www.justice.gov/humantrafficking/what-is-human-trafficking","replyToPid":424758}
发表于 2021-5-9 00:57:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"Did anyone else notice the byline?  KTRK?  K truck?\n\nNice","replyToPid":0}
GMT+8, 2026-2-7 21:17 , Processed in 0.065468 second(s), 24 queries .
