查看: 184|回复: 4
Detroit Diesel dd15 bolt torques and manuels
 楼主| 发表于 2021-5-7 12:40:01 来自手机 | 显示全部楼层 |阅读模式
{"text":"does anyone know where i can get the torque specs for a 2009 dd15 oil cooler housing and thermostat?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
禁止发言
发表于 2021-5-7 18:41:48 来自手机 | 显示全部楼层
禁止发言
发表于 2021-5-7 18:42:29 来自手机 | 显示全部楼层
发表于 2021-5-8 02:47:10 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"You might get lucky and find some free PDF manuals online, but generally the workshop manuals will come at a cost. They’re not expensive though, and you don’t need all the workshop manuals. There are really only like 4-5 useful workshop manuals. Look for a website called MyPowerManual. Get your Detroit DD15 manuals from there, but first make sure your engine really is a DD15. Call Freightliner and give them your last six of the VIN. They’ll tell you what you have.\n\nIf you own the truck, you can also get free access to all of the online manuals, but it’s a pain to get it all set up. The website is Daimler DTNA Connect. The place where you bought your truck will be the one opening an account for you and also approving you access to the online workshop manuals."}
发表于 2021-5-8 02:52:42 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Oil cooler\n(located behind oil coolant module)\n18-22 ft lbs and torque in a star pattern.\n\nCoolant thermostat\n(Not the oil thermostat)\nTorque four bolts to 22 ft lbs. "}
GMT+8, 2026-4-17 05:59 , Processed in 0.090316 second(s), 23 queries .
